coolant leak under intake - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-13-2019, 07:22 PM Thread Starter
Date registered: Apr 2018
Vehicle: 2011 E350
2011 E350 Bluetec -after getting my oil changed today, the mechanic took me under the engine to witness a slow coolant leaking like stalactites under what he said was the intake valve/manifold. I don't remember. Anyway, has anyone ever had this before, and if so, what's a girl to do?
#11BenzAZE350 is offline
post #2 of 3 (permalink) Old 06-14-2019, 12:52 AM
PSDCamperVan's Avatar
Date registered: Jul 2015
Vehicle: 2005 E320 CDI (SOLD); 2008 ML320 CDI 4MATIC
Quoted: 34 Post(s)
There is a peculiar o-ring between thermostat housing & coolant hose with a quick-disconnect type fitting that had a slight cut in it on mine which would cause it to leak but only once up to operating temperature & pressure so tracking it down required observing engine once warmed up to see it dripping.
PSDCamperVan is offline
post #3 of 3 (permalink) Old 06-18-2019, 06:20 PM Thread Starter
Vehicle: 2011 E350
thank you PSDCAMPERVAN. I remembered that about 8 months ago, my mechanic replaced the upper radiator hose. I don't think that's where its leaking from, but suspicious. So this last weekend I put some Blue Devil Stop Leak in the radiator. I'm going to check it this weekend to see if the leak has ceased.
  Mercedes-Benz Forum > General Mercedes-Benz Forums > Diesel Discussion
