Lack of power low range - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-19-2019, 08:47 AM Thread Starter
Date registered: Oct 2017
Hi everyone my car is a w204 c200d and is struggling with low end power anyone else having this problem any help would be great
Sent from my SM-G950F using Tapatalk
ips24 is offline
post #2 of 4 (permalink) Old 05-20-2019, 03:22 PM
Date registered: Jan 2016
Vehicle: 1984 300D Turbo
I just picked up a 300DT with a similar issue, and a diesel purge solved the problem. In other words, cleaning the injectors was all that I needed to do.
castnblast is offline
post #3 of 4 (permalink) Old 05-27-2019, 06:38 AM
Date registered: Jul 2018
Vehicle: 1981 300SD W126
Quoted: 15 Post(s)
+1 on the diesel purge, use liquimoly and change the fuel filters if you have not done so recently
81300SD is offline
post #4 of 4 (permalink) Old 07-03-2019, 03:34 PM
Date registered: Nov 2010
About 20 years ago someone told me about mixing ATF into their fuel to clean out the fuel system.
They did this on both their gas engine and diesel cars and reported good results.
This made sense to me, since it was one of the 3 "cleaners" we used to use in the auto shop to clean out cylinders (the other two being diesel fuel and water. All poured very slowly into the carburetor with the throttle held wide open. Only use one of three, not all 3 at once).
Anyway, I tried this in my gas powered truck. I added one bottle of ATF (I used the generic brand offered at Walmart, since it was the cheapest I could find) to a full tank of gas (14.8 gallons).
Worked great. My truck hadn't run that good in years...however, it only worked the first time, and that made sense too. Once you get the cylinders clean, you can't really "re-clean" them. However, maybe an occassionial application, in order to keep things clean would help (of course, so would allowing the engine to run long enough to properly heat up, then cool down, like its supposed to, rather than just running it cold on almost a daily basis like I had been at the time).
Anyway, I'll leave you the choice of whether you want to try this or not, but in my case, it did work.
It was only a couple of bucks, and the only work I put into it was to go out and buy the ATF, then pour it into the tank.
Dean
DeanMk is offline
  Mercedes-Benz Forum > General Mercedes-Benz Forums > Diesel Discussion
List of Fault Codes....(DTC) sgtpepperaut W163 M-Class 17 06-24-2019 03:17 PM
lack of power, stuttering, low mpg in D bgalakazam W123 E,CE,D,CD,TD,TE Class 0 01-25-2012 12:35 AM
Useful links 4 new members - repost Bazzle R170 SLK-Class 79 02-06-2011 09:45 PM
Check engine light e320 cc238 W210 E-Class 16 06-26-2009 05:47 AM
Error Codes A Plenty.... TheOgre W163 M-Class 2 01-18-2006 06:52 PM
