OM651 No power under 2500rpm - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 04-24-2019, 06:29 AM Thread Starter
Date registered: Apr 2019
Vehicle: 2010 C220 CDI AMG-line
Hi!
I have a trouble with my c-class late 2010 (om651 170hp, 722.626) . When i drive away thereīs no power in the enginge untill i came to 2500rpm then it goes as it schould. After a restart the power will be back untill i hit the highway and the power dissapearīs again. I changed the vacuum transducer and looked after leak in the intercooler hooses. It started a few weeks ago but now it happens everyday.
Engine and gearbox goes into limphome and engine light comes on a few times (not every time). But after restart it goes properly again (untill i cruise at the highway)
Trouble codes :
p226300 - The boost pressure deviates from the specified value (CURRENT & STORED)
p00af92 - Boost pressure control "A" has a malfunction. The function or the instruction is faulty (STORED)
Dammet is offline
post #2 of 5 (permalink) Old 04-24-2019, 06:19 PM
Kajtek1's Avatar
Quoted: 1938 Post(s)
Boost code calls for checking any leaks in the turbocharging system.
Usually they show as wet spot on the hoses or turbo.
How many km on the engine and turbo?
Kajtek1 is offline
post #3 of 5 (permalink) Old 04-24-2019, 09:34 PM Thread Starter
The engine is dry so i Believe there's no leak. I changed both seals on the hose from the turbo to the intercooler cause it was wet. engine has now 350,000 km
Dammet is offline
post #4 of 5 (permalink) Old 04-25-2019, 10:34 AM
Kajtek1's Avatar
At this mileage the turbo might be worn.
Open inlet hose and check ply on the shaft and any damages.
Try to spin it and count the time to stop.
Kajtek1 is offline
post #5 of 5 (permalink) Old 04-25-2019, 10:56 AM Thread Starter
Thanks for your advise, today i find the problem. It was the transducer underneth the egr cooler, i had only changed the transducer on the front of the enginge before.. the car runs great again 😁👌 i'm just curios, for how long time will the turbo spin if it's not damaged?
Dammet is offline
  Mercedes-Benz Forum > General Mercedes-Benz Forums > Diesel Discussion
Intermittent loss of engine power due to electrical problem jwtw210 W210 E-Class 3 12-26-2017 08:22 AM
1990 190E (new to me) paul0130 W201 190-Class 52 04-08-2015 09:58 AM
Germany may be able to lead the way Check Codes Off-Topic 11 03-25-2011 01:14 AM
Money and power: A toxic bond Teutone Off-Topic 3 06-05-2009 07:09 AM
