W115 diesel engine options - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 04-14-2019, 10:34 AM Thread Starter
Date registered: May 2009
Vehicle: 1998 c180 elegance auto
Hi All,
A mate has recently imported a w115 220d from California.Although a solid car,it's a non runner,and on inspection it has broken a camshaft mount.I've pulled the head to find No.1 piston has rotated enough for the injector to beat it up a bit.I suspect a broken con rod or failed big end cap,but wondered if a replacement engine might be a better idea.
My question is,what can i fit without too many mods? Will a 300d from a w123 fit ?
Thanks in advance for any help you can offer
Ed
rodntod is offline
post #2 of 3 (permalink) Old 04-14-2019, 11:44 AM
Kajtek1's Avatar
Quoted: 1892 Post(s)
Nice project.
Can you buy W123 engine easy?
If you are up into big project, consider new generation diesel.
There is UK owner posting on W210 section where he put newer diesel in W124 body.
It is not a small project by any means as you car doesn't have reluctor rings, but if you do it, you will have a car that will have performance, economy and will keep you smiling for next 40 years.
Kajtek1 is offline
post #3 of 3 (permalink) Old 04-14-2019, 12:42 PM Thread Starter
There is a 300d with an autobox for sale not too far away,taken from a S123 with 250.000 miles on it. I have heard it run ,just not sure if it's worth buying or if it's too much work to make it fit in the 114/115 .Autobox is no good to me,so would only be using the engine.
rodntod is offline
  Mercedes-Benz Forum > General Mercedes-Benz Forums > Diesel Discussion
Engine swap options for the R107 jwells R/C107 SL/SLC Class 40 01-29-2018 06:43 PM
Removing the engine on a 500SL, step by step hchaugli R/C107 SL/SLC Class 42 01-12-2017 02:15 PM
W123 N/A diesel engine into W115... W126 oil filter housing or remote-style? TeflonFetus W123 E,CE,D,CD,TD,TE Class 1 11-14-2012 06:01 PM
Cam Oilers and Sludge Removal 97e420sweet W210 E-Class 14 01-14-2009 08:58 AM
w201 diesel engine options tss W201 190-Class 15 10-04-2008 09:10 AM
