1998 E300TD engine wobble. ( oscillation at idle) - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 04-07-2019, 07:24 AM Thread Starter
Jetdude1010's Avatar
Date registered: Aug 2016
Vehicle: 1995 E300D
Quoted: 40 Post(s)
Hi All,
i have the strangest engine wobble at idle on my
OM606.
Its interment, rocking oscillation at normal operating temps. Doesn't do it when cold.
I replaced the engine mounts and trany mount hoping it would fix it. All it did was smooth is out but it still there.
Some days its smooth so its not a harmonic balancer.
Could it be a bad injector? or IP regulating itself out of sync?
Its a weird one.
The car drives fine in all other RPM ranges.
But eventually it will take out the new engine mounts if not fixed.
Jetdude..
Jetdude1010 is offline
post #2 of 3 (permalink) Old 04-09-2019, 08:05 AM
Kajtek1's Avatar
Quoted: 1977 Post(s)
Mileage?
On newer engines better scanner can run simulated compression test, but not sure that is possible with your engine.
Still the old-fashion high pressure fuel line cracking can pinpoint acting injector.
Kajtek1 is offline
post #3 of 3 (permalink) Old 05-20-2019, 03:27 PM
Date registered: Jan 2016
Vehicle: 1984 300D Turbo
I had similar problem in w123, but was able to recalibrate the injectors with washers to yield proper pressure across all five.
Once done, I did a diesel purge; and now she purrs like she should. No more oscilation.
castnblast is offline
  Mercedes-Benz Forum > General Mercedes-Benz Forums > Diesel Discussion
Injection Pump fuel adjustment for the MW and M pumps, engine tuning and maintenance Forcedinduction W123 E,CE,D,CD,TD,TE Class 5 11-28-2017 01:19 AM
90 420SE // Normal ICV Voltages? // High Idle Teddyen W126 S,SE,SEC,SEL,SD,SDL Class 18 07-30-2017 07:06 AM
Why is my car running hot? ScottinSoCal R/C107 SL/SLC Class 18 08-17-2014 11:16 AM
1992 190e will not start halecuda W201 190-Class 29 06-17-2008 10:58 PM
1998 E300TD engine stutter while AC is off cgonz033 W210 E-Class 3 05-16-2007 03:58 PM
