From 0 to 1 MPH in 100 yards. 1995 e300d very slow off the line - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 04-03-2019, 10:58 AM Thread Starter
Date registered: Dec 2014
Vehicle: 1996 E300 Diesel
My 1995 E300 diesel has developed a problem where it doesn't want to start rolling until it has moved about 100 yards at 1 MPH. If there is an up grade, it won't make the grade. After about 100 yards, it starts picking up speed and will do the city speed limit but it shifts at a high RMP. I thought it might be a plugged fuel line so I checked the fuel tank filter and found a lot of what looked like black algae which I cleaned out thoroughly, but that didn't solve the problem. Next, I thoroughly cleaned and lubed the accelerator linkage, but that wasnt' the problem. It still has no power off the line but moves along okay after it gets a long running start. I was getting a lot of middle finger salutes from drivers who were behind me and got stuck at the signal light because it took my car too long to cross the street! :-)
I put the OBD reader on it and got an error code for Fuel Rack Position Sensor (L7) and an error code for EDS Control Unit N39, internal voltage supply.
I am having a lot of trouble finding any data on this with Google search or even YouTube, or anywhere else. Can't even find diagrams for the parts indicated on the error code, so I don't know what they even look like. Obviously, I am not much of a mechanic but I want to learn how to keep this old diesel Benz road-worthy.
I know Mercedes-Benz puts a lot of "engineered for obsolescents" parts on their cars, but these machines roll along so smooth and give such a very nice drive, I'm addicted. How can I fix this old beauty?
Banjoism is offline
post #2 of 8 (permalink) Old 04-03-2019, 11:05 AM
Kajtek1's Avatar
Quoted: 2003 Post(s)
Those are first years of car digitizing, so don't relay on scanners too much.
When you have seen algae -single cleaning might not be enough.
Sometimes it takes 2-3 fuel filter replacement to filter it all.
Than is your engine having intake flap?
Those are common problems in those years.
Kajtek1 is online now
post #3 of 8 (permalink) Old 04-05-2019, 09:17 AM Thread Starter
Thanks for the advice. The tank is clean as are the filters. Yes, there is an intake flapper. I'll have a look at it.
Banjoism is offline
post #4 of 8 (permalink) Old 04-05-2019, 10:19 AM
CheckEngine's Avatar
Date registered: Dec 2017
Vehicle: 1999 C280 (sport), also 2001 SLK230
Location: Redding, CA (for now) Boston, MA, & Mexico City
Quoted: 13 Post(s)
Are you sure this isn't a transmission problem? In that vein, have you checked the battery? Low battery voltage can cause weird problems with the 722.6 transmission, which is what I believe your car is equipped with. How many miles on the car? How long have you had this problem?
CheckEngine is offline
post #5 of 8 (permalink) Old 04-07-2019, 07:47 AM
Jetdude1010's Avatar
Date registered: Aug 2016
Vehicle: 1995 E300D
Quoted: 42 Post(s)
The 95' E300D has an all mechanical transmission. Only a throttle shift cable and vacuum line go to it.
Jetdude
Jetdude1010 is offline
post #6 of 8 (permalink) Old 04-09-2019, 10:44 AM Thread Starter
Thanks Folks for the advice. I work on my cars outdoors. So, the weather is a bit of a problem but spring is around the corner. The battery is new. I don't think its a transmission problem because it gets very low RPM. Once it speeds up it starts shifting okay.
The rainy season seems to be just about over here in California so I am anxious to try some of these tips. I have a 1995 and a 1996 E300 model diesels so I am not stuck for transportation. But keeping them both running is a bit of a trick since Mercedes engineers so many "got-ya's" into their cars. It's bad enough when a part fails, but when it is purposely engineered to fail ... well that is a problem.
Banjoism is offline
post #7 of 8 (permalink) Old 04-09-2019, 11:25 AM
Kajtek1's Avatar
Well.. the 2 MY you have were experiments IMHO.
The NA diesel has lousy power curve and the intake flaps have been headaches for lot of owners.
If I remember it right, in 1994 MB made turbo diesels and in 1998 again.
You are just between good years
post #8 of 8 (permalink) Old 07-01-2019, 12:29 PM Thread Starter
Thanks for all the advice, Folks. I replaced all the old leaky rubber vacuum lines and found that the previous owner had routed two of the lines wrong. Now it runs fine.
Kajtek1 likes this.
Banjoism is offline
  Mercedes-Benz Forum > General Mercedes-Benz Forums > Diesel Discussion
Fuel System Service BenzHacker R/C107 SL/SLC Class 14 01-17-2016 07:24 AM
1995 Mercedes Benz E300D Diesel, 51k miles, one owner POS For Sale/Wanted/Trade/Giveaway 2 08-21-2008 06:39 AM
Biodiesel. Preparing the E300D for it. cdw904 W124 E,CE,D,TD Class 10 03-19-2007 05:46 PM
Vacuum line to nowhere and slow shut off. App_Benz W123 E,CE,D,CD,TD,TE Class 3 11-11-2006 12:23 PM
Is the 300SD really that slow off the line? Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 11 06-28-2002 07:48 AM
