1995 w124 e300d - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 03-31-2019, 08:45 AM Thread Starter
Date registered: Mar 2019
1995 w124 e300d
I just bought this car and one thing I noticed is that when I unlock it the alarm system seems to stay on, and when I open the door the alarm goes off what could be making it do this and all the doors are unlocked and the trunk is locked so I have no idea and this is my first car I’m 16 and learning about it.
Chillpill 96 is offline
post #2 of 9 (permalink) Old 04-07-2019, 02:18 PM
Jetdude1010's Avatar
Date registered: Aug 2016
Vehicle: 1995 E300D
Quoted: 40 Post(s)
Original alarm? Aftermarket? if so disconnect it and see what happens. noone wants to steal the car at this point. lol
Jetdude1010 is offline
post #3 of 9 (permalink) Old 04-07-2019, 02:20 PM Thread Starter
Where do I disconnect it at?
post #4 of 9 (permalink) Old 04-08-2019, 01:27 PM Thread Starter
I was messing with the anti theft box in the passenger foot well and there’s a big plug on it I try to put it off the clip on the back of it comes and the wires just come out the part number is 126 820 24 26 is there anywhere I can find a wiring chart or am I screwed?
post #5 of 9 (permalink) Old 04-11-2019, 06:45 AM Thread Starter
I fixed the 14 pin but I don’t think it’s all wired right because I don’t hear any audio from my speakers and the antenna feeding through the whole if someone has the diagram of the wires can you please send me the link I like to have music playing when I drive.
post #6 of 9 (permalink) Old 05-10-2019, 02:35 PM Thread Starter
I fixed my alarm system. I have 2 more problems I’m losing coolant I poured destined water in the coolant tank left it for 3 hours and some of it went down I have no idea where it could be leaking from. My second problem is my auxiliary fans won’t work I changed the fuses to the fans and the relay I check the strip fuse that’s fine what else could it be I don’t think the fans have debris in them I could check on the radiator to see if there is anything behind them. I’d greatly appreciate the help I’m still learning about this car as it is my first.
post #7 of 9 (permalink) Old 05-10-2019, 02:36 PM Thread Starter
Distilled water*
post #8 of 9 (permalink) Old 05-19-2019, 11:24 AM
ot1
Date registered: Apr 2007
Vehicle: 2006 E320 CDI
Quoted: 143 Post(s)
When you put the distilled water in and you find its not leaking was the engine running at anytime during the 3 hours?
Possibilities:
The coolant was already low in the radiator
The water pump is slinging the coolant/water and its evaporating.
You have a bad radiator, not sure but many have the transmission cooler built in and the distilled water in getting into the transmission, but probably not.
Check the oil for contamination of water too
ot1 is offline
post #9 of 9 (permalink) Old 05-19-2019, 11:28 AM
ot1
Quoted: 143 Post(s)
You have two engine fans?
On my 06 CDI usally the left most fan only operates when the A/C is on.
ot1 is offline
  Mercedes-Benz Forum > General Mercedes-Benz Forums > Diesel Discussion
Can it be done? 1995 E320 trany in a E300D? Jetdude1010 W124 E,CE,D,TD Class 2 06-08-2017 02:16 PM
1995 E300D W124.584 w/OM606.910 for sale [email protected] W124 E,CE,D,TD Class 0 12-01-2014 01:26 PM
1995 E300D pricing? ValveCoverGasket W124 E,CE,D,TD Class 28 01-06-2014 12:00 PM
Oil Pan Replacement 1995 E300d w124 testudo W124 E,CE,D,TD Class 4 12-11-2013 07:17 PM
Buying a w124 1995 300d, need advise spmarfatia W124 E,CE,D,TD Class 3 05-16-2009 07:05 PM
