1997 e300d w210 - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 03-23-2019, 03:00 PM Thread Starter
Date registered: Mar 2019
1997 e300d w210
I have replaced the k40, all the plastic fuel lines, both fuel filters. When cranking will pull fuel up to fuel filters still no start. When stop cranking the fuel goes back down fuel heater. I pressurized the tank with compressed air. Still no start. We can hear sav click and feel it click when key is turned on. Anyway to diagnose lift pump failure? Car was running fine 1 week ago, parked it in a garage and 1 week later. Don’t think it’s algae. Have not check fuel screen on tank.
Chillpill 96 is offline
post #2 of 6 (permalink) Old 03-24-2019, 08:36 AM
Kajtek1's Avatar
Quoted: 2003 Post(s)
Did you replace orings at prefilter and SOV?
Top off your tank for easy priming after the job.
Without high fuel level - it does takes lot of cranking.
Kajtek1 is offline
post #3 of 6 (permalink) Old 03-24-2019, 08:45 AM Thread Starter
We changed all the plastic lines is there a separate orings for that sav. Next step is changing the strainer on the tank don’t want waste 20 gallons of fuel.
post #4 of 6 (permalink) Old 03-25-2019, 12:32 PM
Date registered: Dec 2009
Vehicle: 1997 E300D
Quoted: 34 Post(s)
Originally Posted by Chillpill 96 View Post
We changed all the plastic lines is there a separate orings for that sav. Next step is changing the strainer on the tank donít want waste 20 gallons of fuel.
There are only the ones on the fuel lines, unless you remove the sav and then there is one between it and the injection pump. There is an extra large oring on the pre-filter that people often miss. There is also an oring where the return line fitting goes into the filter assembly, which if it leaks air can let fuel go back to the tank. If you put a vacuum device on this port you can draw fuel through most of the fuel system. Since you say that the fuel runs back, you have an air leak somewhere or the fuel would not run back.
nelbur is offline
post #5 of 6 (permalink) Old 03-26-2019, 09:49 AM
E50Canuck's Avatar
Date registered: Jun 2013
Vehicle: 1998 E300TD
Quoted: 81 Post(s)
How long did you crank? Takes at least 7 or 8 tries before the system gets primed, assuming you don't have any leaks.
E50Canuck is offline
post #6 of 6 (permalink) Old 03-28-2019, 12:56 PM Thread Starter
1995 e300d w124
We’re putting the w210 on the back burner we bought a 1995 w124 e300d om606 I need to know what kind of coolant and differential fluid for the car.
  Mercedes-Benz Forum > General Mercedes-Benz Forums > Diesel Discussion
1997 W210 wheels the same as 2001? jaymaynard W210 E-Class 3 06-26-2013 10:16 PM
W210 Recalls and in particular 1997 E300 mike93108 W210 E-Class 4 12-01-2012 09:18 PM
For Sale 1997 E300D GreatWhiteDan For Sale/Wanted/Trade/Giveaway 4 07-18-2010 06:29 AM
WTB: Passenger Side Electric Seat Adjustment for 1997 W210 E36_AMG For Sale/Wanted/Trade/Giveaway 2 04-26-2010 12:56 AM
1997 E300D VS 1996 E300D briandownunda W210 E-Class 11 06-25-2009 02:18 PM
