Fumes in Cabin - Page 2 - Mercedes-Benz Forum
post #11 of 17 (permalink) Old 05-12-2019, 05:56 AM
ot1
Date registered: Apr 2007
Vehicle: 2006 E320 CDI
Quoted: 143 Post(s)
Originally Posted by mtrevelino View Post
ok, just to bring everyone up to date on this and to close this out. One month and 1,500 miles ago, I replaced the oil separator with a Viaco brand oil separator. The oil smell decreased by at least half immediately. During the following weeks and finally today, I can say the smell is completely gone.
I stopped by my indie and spoke to him a couple of weeks ago while the smell was still there. He said that the first thing he would have checked was the oil separator. I stopped again this morning and told him the smell was completely gone. He said that when I changed the oil separator and without thoroughly cleaning the system, that it could take a week or two for everything to resume to normal. He said that there could have been oil stuck in places it should not have been, and took time to clear.
Anyway, that is my story. Thanks for those that offered suggestions.
Mike T.
Do you have the part number for the oil separator?
ot1 is offline
post #12 of 17 (permalink) Old 05-12-2019, 07:51 AM Thread Starter
Date registered: Jul 2010
Vehicle: 2006 e320 CDI
Quoted: 65 Post(s)
Here is a quick internet search:
https://www.google.com/search?client...=mb+6460101462
I got mine from rmeuropean.com under this part number:
6460101462-MFG604
I paid $122 for it. It looks like they are out of stock, but their price is $78.
Mike T.
ot1 likes this.
mtrevelino is online now
post #13 of 17 (permalink) Old 05-13-2019, 02:19 PM
ot1
Quoted: 143 Post(s)
6460101462-MFG604
Mike T.
Thanks for the part number, mercedes calls it an oil drip pan, ECS does call it an oil separator, but doesnt show up under 06 e320, a search wihout the part number in the parts houses was frustrating,
ot1 is offline
post #14 of 17 (permalink) Old 06-12-2019, 03:32 AM
Date registered: Mar 2013
It seems like you have solve the smell problem with the oil separator.
Other smell are The fuel filter connections tend to leak. I used a larger o-ring to stop the leak from the sensor. Hose was also leaking, replaced.
If oily smell, the oil drops on the dfp or exhaust that is right under HVAC air filter in the right side/firewall engine compartment.
A terrible design.
IND Mechanic said lower oil pan $400. replaced but that was not source of the leak.
Then said upper oil pan. $1000 job.
Another IND said upper oil pan was definitely not the source, but could not locate the source.
Oil in the bell housing, so rear main seal or draining from the oil cooler.
2009 bluetec with 110,000 miles. Had turbo, flapper motor, front wheel bearings and glow plug relay replaced. Seems to need alot of repairs.
The oil leak is splashing even to the alternator and could short out some computer and sensor. Half to 1 liter oil loss per 6,000 mile. AT-200 leak stop didn't work or made it worse.
Question:
Pull the engine and fix both of them at same time ($2500?) or just use until it dies?
dave84_300d is offline
post #15 of 17 (permalink) Old 06-12-2019, 04:57 AM Thread Starter
Quoted: 65 Post(s)
Sorry, I cannot help you with your bluetec motor. Replacing my oil separator on my cdi did fix the cabin fumes, but I have a small oil leak where oil is puddling along the ridge of the separator. I have wiped it down and will try to pinpoint the leak. I think it may be coming from the hose that goes into the front of the separator.
Mike T.
Name:	Oil Separator.jpg
post #16 of 17 (permalink) Old 06-12-2019, 07:21 AM
The connection of that hose to the air tube tends to leak. I wipe off all the oil with isopropyl alcohol. Add some water for a temporary lube to fit it snuggle. Same for the air tube to the turbo. Connected to unbolted air filter box. Fit, tighten to turbo, then final bolt down air filter box.
mtrevelino likes this.
post #17 of 17 (permalink) Old 06-12-2019, 02:07 PM Thread Starter
Quoted: 65 Post(s)
Thanks! I will give it a good cleaning and maybe put a hose clamp on it.
Mike T.
  Mercedes-Benz Forum > General Mercedes-Benz Forums > Diesel Discussion
DIY Step-by-step Guide: Air Filter, Fuel Filter, Cabin Filter Change for the CDI Cowfunone W164 M-Class 4 08-26-2013 12:42 PM
Diesel fumes in cabin chompsticks W124 E,CE,D,TD Class 1 03-31-2013 05:45 PM
2003 270 CLK Diesel W209(?) - Fumes in cabin aiderz General Mercedes-Benz 4 10-16-2012 03:02 PM
1995 E320 - Fumes in Cabin - Please Help! Shade2 W124 E,CE,D,TD Class 11 07-04-2009 01:13 AM
exhaust fumes in cabin roempty W123 E,CE,D,CD,TD,TE Class 1 09-01-2004 08:14 PM
