Sludge signs after Oil change on my 07 E320 OM642 - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 10-27-2018, 09:09 AM Thread Starter
EFSiR's Avatar
Date registered: Feb 2013
Vehicle: 2007 W211 E320 Bluetec
Quoted: 55 Post(s)
I used 2 bottles (1L total) of liqui moly engine flush just prior to my oil change. Draining the old oil didn't result in any chunks of sludge or debris in the oil but my magnetic oil drain bolt did grab what appeared to be sludge. Have a peak at the picture. I also pulled my intercooler off thinking it will have crap load of oil but no, nothing! Just oil condensation. I had the intercooler standing up right thinking some oil will drain but nothing. So that's a nice surprise.
Visual inspection through the oil fill cap and down the oil filter valley doesn't reveal any sludge. I'm thinking of scoping the oil pan.
This time, I changed my oil at 9,000km and purchased dealers 5w30 229.52. It's not cheap. 😕
ID:	2461871   Click image for larger version
ID:	2461873   Click image for larger version
The ultimate ignorance is the rejection of something you know nothing about and refuse to investigate.
Dr. Wayne Dyer
EFSiR is offline
post #2 of 13 (permalink) Old 10-28-2018, 01:02 AM
Kajtek1's Avatar
Quoted: 1976 Post(s)
I hope you send sample to the lab?
Strange as I torn apart my old 2008 engine and at 180k miles not even slightest sign of sludge.
Could be different oils, or different temperatures?
Kajtek1 is offline
post #3 of 13 (permalink) Old 10-28-2018, 07:10 AM Thread Starter
EFSiR's Avatar
Quoted: 55 Post(s)
No I didn't even though i had the sample kit ready. There were no signs of any sludge before and at half the recommended change interval I didn't think it was needed. I noticed this buildup of on the magnet after so yes next time I'll send a sample in for analysis.
This was MB oil that I drained but before I had Amsoil.
Dr. Wayne Dyer
EFSiR is offline
post #4 of 13 (permalink) Old 10-28-2018, 04:41 PM Thread Starter
EFSiR's Avatar
Quoted: 55 Post(s)
Small update. It was suggested that this magnet buildup is not sludge but sub 20 micron metal particles and the magnetic drain magnet is doing its job. If in fact that is the case, I better send oil for analysis!
Dr. Wayne Dyer
EFSiR is offline
post #5 of 13 (permalink) Old 10-30-2018, 07:00 PM
Premium Member
Date registered: Dec 2017
Vehicle: 07 GL320CDI
Premium Member
From my mechanical experience what I see on your magnetic plug doesn't look like anything to worry about. I'd just change the oil sooner.
GLJack is offline
post #6 of 13 (permalink) Old 10-31-2018, 02:46 PM
Kajtek1's Avatar
Rubbing the residue between fingers, or white paper towels should show if that is sludge, or steel dust.
Kajtek1 is offline
post #7 of 13 (permalink) Old 11-01-2018, 11:45 AM
MBGraham's Avatar
Date registered: Oct 2006
Vehicle: '72 350SL, '85 300D, '98 E320, '19 Subaru Outback (sold '14 GLK250)
Quoted: 20 Post(s)
Collect "sludge" in plastic dish then see if attracted to magnet?
1972 350SL 4.5L, E320, 300D, Outback 2.5 - near Kingston, Ontario
MBGraham is offline
post #8 of 13 (permalink) Old 11-01-2018, 12:32 PM Thread Starter
EFSiR's Avatar
Quoted: 55 Post(s)
I think it was both. It had grayish metallic colour on the white rag as whipped it off the drain plug but when I picked it with my fingers I was able to roll it like a nose booger
Dr. Wayne Dyer
EFSiR is offline
post #9 of 13 (permalink) Old 11-01-2018, 01:43 PM
Kajtek1's Avatar
That sounds like metal shavings with oil attached to them.
To some degree normal, but too much for my taste.
I would keep an eye on it and definitely send next sample to the lab.
What oil did you use?
Kajtek1 is offline
post #10 of 13 (permalink) Old 11-01-2018, 04:01 PM Thread Starter
EFSiR's Avatar
Quoted: 55 Post(s)
I drained MB (I think it was MB 0W30) Oil but before I had Amsoil. Now I filled up with MB 5w30.
Dr. Wayne Dyer
EFSiR is offline
  Mercedes-Benz Forum > General Mercedes-Benz Forums > Diesel Discussion
