2012 c350 om642 Engine management light - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 09-28-2018, 02:37 PM Thread Starter
Date registered: Jan 2009
Quoted: 2 Post(s)
Hi I have done the oil cooler seals today on this c350 om642 and on competition I test drove and seem to have the management light on I’ve scanned it and it’s logged error 15f500 the signal voltage of component b17/8 (charge air temperature sensor) is to high.
Can anyone guide me to where this sensor is and what it looks like?
Cheers
sprinterrob is offline
post #2 of 5 (permalink) Old 10-22-2018, 04:28 PM
ot1
Date registered: Apr 2007
Vehicle: 2006 E320 CDI
Quoted: 145 Post(s)
Originally Posted by sprinterrob View Post
Hi I have done the oil cooler seals today on this c350 om642 and on competition I test drove and seem to have the management light on Iíve scanned it and itís logged error 15f500 the signal voltage of component b17/8 (charge air temperature sensor) is to high.
Cheers
How difficult was it to replace the oil cooler gaskets? I see the gaskets are only $4.00
ot1 is offline
post #3 of 5 (permalink) Old 10-28-2018, 01:05 AM
Kajtek1's Avatar
Quoted: 2003 Post(s)
Charging air temp is measured by MAF to my knowledge, so you might be a due for new one.
About the oil cooler gaskets - it is funny that they cost $4, takes less than 1 hr to replace them on the cooler, but 12 hr just to get to darn cooler.
Kajtek1 is online now
post #4 of 5 (permalink) Old 10-31-2018, 06:35 PM
Date registered: Oct 2018
It's located at the throttle body on the underside, just above the alternator. It would be passenger side front fairly low down on the intake manifold, it just has to hook type tangs that hold it in, 2 wire, be very careful unplugging as the wires are small. They are common for oil saturation, when pulled out it looks like 2 wires joined at a plastic looking tip
Cheers
FritoGreg is offline
post #5 of 5 (permalink) Old 11-02-2018, 05:43 AM
Rossafuss's Avatar
Date registered: Oct 2013
Vehicle: 2005 E320 CDI *black on black with nearly every option*
Quoted: 195 Post(s)
check the intercooler fins for blockage as well, that would cause intake temps to increase if the intercooler cant do its job.
Rossafuss is offline
  Mercedes-Benz Forum > General Mercedes-Benz Forums > Diesel Discussion
