'96 e300d thermostat - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 08-03-2018, 08:27 PM Thread Starter
Date registered: Jun 2018
Need to replace the aux pump thing. Figure change stat too, however seeing various temperature values. What would be proper?
Thanks,
Lowell
Lgl61953a1 is offline
post #2 of 3 (permalink) Old 08-04-2018, 03:20 PM
Kajtek1's Avatar
Quoted: 2003 Post(s)
Part crucial for proper car operation you should buy only from sellers who can match the part to your VIN.
Diesels of the era had lower temp thermostats. For my 1998 diesel thermostat was rated at 83C, what kept the engine at 78C on normal cruising.
Kajtek1 is offline
post #3 of 3 (permalink) Old 08-07-2018, 05:10 AM
~PERMA BANNED~
Date registered: Mar 2006
Vehicle: 1982 300D
Quoted: 152 Post(s)
If an 83c thermostat kept the engine at 78c, it wasn't working correctly.
The operating temp will always be slightly above the marked temperature of the t-stat. You should have been running about 85c.
Thats why, for example, normal working temperature of a W123 300D with an 80c t-stat is 82c.
Forcedinduction is offline
  Mercedes-Benz Forum > General Mercedes-Benz Forums > Diesel Discussion
