fuel door won't open - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-13-2019, 01:52 PM Thread Starter
Date registered: Jan 2004
Vehicle: 84 300TD, 2005 CDI, 2006 CLS55
Quoted: 80 Post(s)
My CLS55 has a fuel door that won't open. I know there is supposed to be a manual pull cord or something inside the trunk close to the fuel fill but I can't find it. Help please.
MTUpower is offline
post #2 of 4 (permalink) Old 05-14-2019, 02:20 AM
plinker17722's Avatar
Date registered: Mar 2015
Vehicle: 1989 W124 260E
Quoted: 142 Post(s)
You could disconect the battery for 30 mins and then reconect. But dont do this if you dont have the radio code --sopme you do some dont . And you will need to reset the system if you remove the battery conections .
Also to make it easy on me and sothat i dont have to print it off see picture ,Thats if battery removel solves nothing,pictures in next post
This is a retro ride .
plinker17722 is offline
post #3 of 4 (permalink) Old 05-14-2019, 02:23 AM
Quoted: 142 Post(s)
suquence
This is how to get to both relays and fuse .Hope you understand it sorry for bad pictures .
ID:	2512468   Click image for larger version
post #4 of 4 (permalink) Old 05-14-2019, 07:41 AM
konigstiger's Avatar
Date registered: Jan 2007
Vehicle: '71 Pinto
Quoted: 376 Post(s)
Correct, check f15 and G & H @ rear SAM (trunk).
konigstiger is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C219 CLS-Class
Mercedes-Benz Diagnostic Trouble Codes (DTC) for 1996+ models GeeS General Mercedes-Benz 45 03-23-2019 06:04 AM
DIY: 2000 C230 Kompressor Fuel Filter Replacement Mercedes Benz of Florida W202 C-Class 13 10-28-2010 08:50 AM
Blower Motor does not work NewYorkS600 W140 S-Class 8 09-24-2010 11:07 AM
OBDII Scanners and Simple Sensor Diagnostics AC_ML W163 M-Class 2 03-24-2008 10:11 AM
Fuel pressure regulator Vs accumulator NewMBie W126 S,SE,SEC,SEL,SD,SDL Class 2 03-22-2005 01:03 AM
