2005 500 CLS - CD-player cover not moving - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 05-12-2019, 06:55 AM Thread Starter
Date registered: May 2019
Hello everybody,
I'm new and happy to be part of the group.
I recently bought a 2005 w219 CLS 500 and wanted to upgrade the infotainment, so I replaced the Comand with an aftermarket Android-ready version. Since then, the automatic CD player cover no longer works. The CD player uses fiber optics that are no longer connected because they are not compatible with the new Android headunit.
I removed the CD player because I wanted to use the space for a hard-disk and USB jacks.
Of course I did it, but the automatic cover does not open anymore - you can hear the electric motor doing a rattling sound but the cover doesn't move).
Sometimes even without the ignition key inserted you can hear the motor trying to open the cover, but to no avail.
Do you have any idea how to get the CD-player cover working again?
Thanks in advance!
Bubba Doug is offline
post #2 of 2 (permalink) Old 05-12-2019, 07:28 AM
konigstiger's Avatar
Date registered: Jan 2007
Vehicle: '71 Pinto
Quoted: 367 Post(s)
Try reversing fiber optic wiring in attachment covering 211 (should be the same) this will remove CDC from MOST loop. However, note instructions apply to original coupling that was connected to OEM radio not sure how this relates to Android unit. Re-coding MOST loop to remove CDC using MB SDS may also be necessary but again, not certain how this applies to Android install.
File Type: pdf Retrofit fiber optic cable wiring harness.pdf (61.3 KB, 4 views)
konigstiger is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C219 CLS-Class
124 marketplace: Sale/Wanted/Trade/Giveaway elbeik W124 E,CE,D,TD Class 3482 05-15-2019 09:30 AM
CLS 500 - 2005 - Batteries Places Mounir C219 CLS-Class 2 01-09-2012 09:17 AM
Considering CLS 500 to replace W124 (91 300E) and Porsche 911 JJB236 C219 CLS-Class 8 08-04-2007 08:30 AM
