NEW to M273. OIL LEAK burning off exhaust at idle. - Mercedes-Benz Forum
View Poll Results: Questions Select all that apply
Skill Level of DIYer :Beginner 1 100.00%
Skill Level Intermediate 0 0%
Skill Level Professional 0 0%
How much is it for parts $20-$100 1 100.00%
How much is it for parts $150-$250 0 0%
How long to DIY 1.5hr-2hrs 0 0%
How long to DIY 2hr-3hrs 0 0%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
post #1 of 5 (permalink) Old 02-26-2019, 08:41 AM Thread Starter
Bodya's Avatar
Date registered: Oct 2008
Vehicle: 2001 Mercedes Benz ML430 w163,2008 Mercedes Benz CLS550, RIP Mercedes Benz 1996 e320 w210
Quoted: 52 Post(s)
Question NEW to M273. OIL LEAK burning off exhaust at idle.
Good Morning CLS forum,
Its a pleasure to be posting here since owning a CLS is great feeling. Had the CLS550 for year and couple months fun car to drive and zippy.
Moved to a different city the roads potholes here are bigger then the wheels themselves. Have to change the bearing so the car is parked in the garage and have been for couple of days since i am waiting on the Hub assembly w/bearings pressed already. In Kentucky atm according to FedEx.
This morning decided to run the car and after 4 minutes of idling smelt burn oil open hood and there was blue smoke beside the dipstick. Something i have smelt on long traffic lights at rush hour other then that you don't smell it or see it. but also this is my girlfriend/fiances daily since i drive W163.
Last month i have replaced the lungs(air filters) so i decided to remove the rib cage that holds the air filters to take a closer look and take some pictures so you well informed crowd point me in the right direction!
Any help with issue would be awesome!
3rd picture is the culprit what is the name of that part?
Thank you in advance!
PS.
still looking for an app for iPhone so i can quickly reply instead of using my macbook or mobile safari.
ID:	2491992   Click image for larger version
ID:	2491994   Click image for larger version
ID:	2491996   Click image for larger version
LOve W210!
  • E55 W211 AMG Wheels
Daily Driver W163
  • AMG HOOD
  • AMG ML55 Wheels
  • Lamella Panoramic Roof
  • Custom Straight Pipe Exhaust post cat
New Addition, New Problems
CLS550
  • Low Miles
  • Fully Loaded
  • Beauty
  • Looking for CLS63 Wheels
Bodya is offline
post #2 of 5 (permalink) Old 02-26-2019, 10:58 AM
konigstiger's Avatar
Date registered: Jan 2007
Vehicle: '71 Pinto
Quoted: 377 Post(s)
Crankcase breather part # 2730100162 & cover 2720100631. Most likely gasket has failed and cover, which incorporates gasket, needs replacement. Plug & play replacement.
Bodya likes this.
konigstiger is offline
post #3 of 5 (permalink) Old 02-26-2019, 11:30 AM Thread Starter
Bodya's Avatar
Quoted: 52 Post(s)
SUPER! ops caps on
Thank you very much for your input sir! You are a gentlemen and scholar!
I see so just replace the cover great i can definitely do that! Just need to source the part now for cheap and that ships to the big great cold north. Unless you think its best to go to the dealer for the part?
Regards,
B
LOve W210!
Daily Driver W163
  • AMG HOOD
  • AMG ML55 Wheels
CLS550
  • Low Miles
  • Fully Loaded
  • Beauty
Bodya is offline
post #4 of 5 (permalink) Old 02-26-2019, 11:44 AM Thread Starter
Bodya's Avatar
Quoted: 52 Post(s)
Called the dealer in the area. So i am assuming M272 V6 and M273 V8 share the same crankshaft breather part?2720100631
2720100631 available in the dealer for 91 CAD dollars $
and they have 4 in stock. Whoop
2730100162 says its in Toronto and some oil pan and he said it wasn't the gasket. not sure.
2720100631 for $91 dollars getting it now and replacing it right away and forgeting about it would be nice.
just wonder if 2730100162 is gasket or parts guy messed up on something.
I also found one on eBay
LOve W210!
Daily Driver W163
  • AMG HOOD
  • AMG ML55 Wheels
CLS550
  • Low Miles
  • Fully Loaded
  • Beauty
Bodya is offline
post #5 of 5 (permalink) Old 02-26-2019, 07:08 PM Thread Starter
Bodya's Avatar
Quoted: 52 Post(s)
Awesome got the part managed to get genuine for $77 cad plus tax after chatting with parts guy. The breather has gasket inside the cover. Perfect time to install it and forget about for good. Probably should replace cabin air filters because they are probably stunk up with burning oil
LOve W210!
Daily Driver W163
  • AMG HOOD
  • AMG ML55 Wheels
CLS550
  • Low Miles
  • Fully Loaded
  • Beauty
Bodya is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C219 CLS-Class
'94 W124 104 bad oil leak rear engine - VERY FRUSTRATED RamahX W124 E,CE,D,TD Class 7 01-13-2019 03:15 PM
How to DIY oil change on your C230 spoons W203 C-Class 133 06-20-2017 06:38 AM
U.S. Warns Iran Against Closing Oil Passage Teutone Off-Topic 80 01-10-2012 01:06 PM
World oil supplies are set to run out faster than expected, warn scientists Jakarta Expat Off-Topic 1 06-14-2007 06:58 AM
