2011 CLS 550, no A/C - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 04-15-2015, 07:42 PM Thread Starter
Date registered: Apr 2015
Just turned 26,000 miles, has full charge of freon, all fuses are good, all of the climate controls appear to be working correct, the cooling fan is working, scanned, no faults present, no power at the A/C compressor. Any ideas on what to check?
Thanks!
550gcole is offline
post #2 of 3 (permalink) Old 05-20-2015, 10:59 AM
hilarushi's Avatar
Date registered: Jan 2007
Vehicle: W210, W211, W163
Quoted: 6 Post(s)
Are you sure you haven't lost freon? If it is to low it will not send a signal for the compressor to engage. Make sure the engine is runing when you check the low pressure side.
Here is a good troubleshooting guide.
Air Conditioner Troubleshooting Guide & Diagnosis |
You also said you scanned it. Are you using Star to scan it? If you have that you can do several tests on the A/C system. If something is wrong there will be a code stored.
Thanks!
hilarushi is offline
post #3 of 3 (permalink) Old 05-20-2015, 05:59 PM Thread Starter
Thanks for the info, I had a repair shop check it out and the clutch on the compressor was bad, I replaced the compressor and now have cold air.
550gcole is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C219 CLS-Class
