Airmatic malfunction (pic included) - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 12-04-2009, 06:58 PM Thread Starter
Date registered: Feb 2009
got this message car height seams fine all around, just wondering where I should start or should I just go to the dealer and cough up a couple grand which is definitely not budgeted for
dee_seal is offline
post #2 of 13 (permalink) Old 12-04-2009, 07:40 PM
konigstiger's Avatar
Date registered: Jan 2007
Vehicle: '71 Pinto
Quoted: 375 Post(s)
Sender unit may be malfunctioning, replacement parts for your MY07 cls550: left front, right front, and/or rear right acceleration sensor part #0105427717 (for comparison shopping, parts.com $105.80 each). Dealer, independent, or anyone with SDS access can pull up fault code to pinpoint which location is malfunctioning.
konigstiger is offline
post #3 of 13 (permalink) Old 01-07-2010, 08:19 AM
Date registered: Aug 2008
Send a message via Yahoo to The_Dream_CLS
Take it to a shop that's located around your town that only works on German cars and save those thousands man! Trust me! Yellowpages.com or check in this forum for information of someone that's in your area as well.
The_Dream_CLS is offline
post #4 of 13 (permalink) Old 02-02-2010, 02:31 AM
dawid25's Avatar
Date registered: Jan 2010
How to fit in cls350 2006 year airmatic, its that possible, dealer told me that i cant fit this in my car, any help
dawid25 is offline
post #5 of 13 (permalink) Old 02-25-2010, 05:07 PM Thread Starter
I finally got the car to a shop that works on German cars, they did the diagnosis and the pump had to be changed, so he changed the pump and the relay.
We still have a problem
So I visited the shop. He tries to jump the relay from the fuse box and I can hear the pump being engaged, but the air is not transferred to the lines.
The car is on lift, with a new pump and relay, and my car is out for a day. After leaving the shop, I am thinking the car needs to turned on fully for the air to be pumped through the entire system, any ideas?
dee_seal is offline
post #6 of 13 (permalink) Old 03-01-2010, 12:21 PM
Date registered: Mar 2010
I have the same problem today been told its the pump after diagnostics, going to cost £400+
How much should I pay be paying including fitting estimate?
JM51ROE is offline
post #7 of 13 (permalink) Old 03-01-2010, 12:36 PM Thread Starter
I took my car to get repaired it costed me $700.00 US and that included parts and labor. The pump was $370.00 and the relay was $68.00. and there was a fuse as well that was under the dash somewhere not too sure about that , but that was replaced as well. So £400+ sounds about right.
These cars can be a pain in the Ass whenit comes to repairs
dee_seal is offline
post #8 of 13 (permalink) Old 03-01-2010, 12:43 PM
Thanks mate, guess Im going to have to pay up
JM51ROE is offline
post #9 of 13 (permalink) Old 03-15-2010, 06:59 PM
the cls and e have issues with the pressure relief valve located on the pump. the harness connector wires break right at the connector causing a malfunction. this is the most common airmatic issue on the cls and e. if u take off the lf wheel and fender liner. there are 2 connectors on the airmatic pump. the connector to the release valve is with the 2 thinner wires. wiggle them and see if u have a broken wire.
mbtech101 is offline
post #10 of 13 (permalink) Old 07-10-2010, 08:50 PM
Bigpunch8's Avatar
Date registered: Feb 2008
Samething happened to my car. I had to get a new pump, but warranty covered everything!! They said it would of cost me $600.
Bigpunch8 is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C219 CLS-Class
Airmatic malfunction - Visit workshop barneyundfred W220 S-Class 3 02-24-2009 05:51 AM
s 430 airmatic malfunction yayaz23 General Mercedes-Benz 0 02-16-2009 09:10 AM
Does my car have asr?? (dash pic included) blown W124 E,CE,D,TD Class 11 09-14-2008 06:23 PM
AMG 300e bodykit pic included stereo W124 E,CE,D,TD Class 7 08-07-2008 06:39 PM
Recent 1999 ML430 Purchase and New to Forum; PIC Included! CCORLEY W163 M-Class 17 01-22-2004 08:34 PM
