Park Assist Question - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 12-09-2018, 10:43 PM Thread Starter
Date registered: May 2008
Vehicle: 1990 190E 2.3
Hi,
In a 2015 CLS400, Does the Park Assist look out for the front of the car when backing into a 90 degree spot i.e. where the car ends up pointing across the road, not parallel parking, but backing in to a normal car spot ?
Reason I ask, is that at work, it is a very tight car park spot with plenty of pillars and cars making it tough to swing the nose around when backing in - I often have to crab in doing 3 or 4 moves, otherwise the nose will hit a pole or car opposite my car park.
Its basically a single lane in the carpark, so I drive past my allocated spot and then reverse in (trying not to swing too wide and avoiding already parked cars on both sides. It is tight.
A bit hard to explain, but if you understand what I mean, then will it help ?
thanks
Doug11.
1990 190E 2.3 25k miles
Doug11 is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C218 CLS-Class
