2014 W218 Dead battery equals dead windows and mirrors - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 09-28-2018, 10:01 PM Thread Starter
Date registered: Sep 2018
Greetings
I am hoping someone can shed some light on the following situation:
Vehicle in question is a 2014 CLS550 (W218) which worked perfectly fine UNTIL I killed the battery. Now the windows and mirror adjustments don't work.
Battery was trickle charged (per MB procedure) via jump start posts for 24hrs.
Battery holds charge, car restarts, no CEL/MIL light but I connect an Autel DS808 (fully updated and running Benz v14.0) and run a diagnostic scan.
That scan reported a few faults including
FCMU05 low voltage
Comand APS open circuit on each speaker
Central Gateway unstable CAN bus/error in CAN bus message Interior CAN bus turned off.
Scanner clears codes, verified codes don't come back, life is good until later that day when I try to roll my window down and nothing happens.
Seems all 4 windows (tried switches on all 4 doors for windows) and mirror adjustments are dead.
The all up and all down functions on the key FOB do activate the windows
I specifically checked the front SAM module and it looks fine
When I access the front left DCM (door control module) via scanner I can activate the windows (verified all 4 windows up/down within range and don't need normalizing) and adjust the mirrors.
All other mirror functions ( park assist, blind spot, turn signal, and dimming) work fine
Anybody have any ideas/suggestions before I start tearing into the door panels?
Possible there is still some current or stored fault code only a STAR scanner will be able to deal with?
theonlykid1 is offline
post #2 of 10 (permalink) Old 09-29-2018, 07:36 AM
konigstiger's Avatar
Date registered: Jan 2007
Vehicle: '71 Pinto
Quoted: 377 Post(s)
Something to try, disconnect engine compartment battery for at least 15 - 20 minutes then reconnect in an attempt to reset.
konigstiger is offline
post #3 of 10 (permalink) Old 09-30-2018, 01:00 PM Thread Starter
Thanks for the responnse man.
Sadly I did try that already. I even went the extra mile and disconnected the ECO batttery in the trunk as well as the main battery for a few hours.
I read in a few places that if you touch the + and - main battery leads together after disconnecting the battery will force some kind of reset. ERRRRR I think I will pass on that one.
I did more research and am more convinced then ever the issue stems from the error message on CAN bus B (B is interior bus) from the central gateway. Even though the scanner is no longer reporting any fault I think something is hanging around somewhere related to that event in the non volatile memory.
I omitted in the initial post that the trunk open/close button also stopped working.
The front left DCU uses both Direct Line and LIN bus lines for communication.
The trunk is on Direct Line S/15 (S15/1 is key FOB and S15/3 is DCU line)
Window and mirror messages run over the LIN bus under the S20 switch group (Windows are S20/s1-4).
The interior CAB bus B manages messages from both the direct line and LIN bus and feeds them to the central gateway.
Since I can control both trunk open and windows up/down from the FOB that tells me that both the Direct Line and LIN bus are up and functional.
I believe that narrows it down to faulty communication between the DCU and CAN bus B.
Grrrrrr, still doesn't tell me how to fix it.
Anybody know if you can force a reset by pulling a relay?
I will press on as I can't stand the steelerships and Benz tax.
post #4 of 10 (permalink) Old 09-30-2018, 01:04 PM Thread Starter
The front left DCU communication is laid out in doc GF72.29-P-6001FQ
Wiring block diagram for LF DCU is covered in PE72.29-P-2101-97XAA
post #5 of 10 (permalink) Old 09-30-2018, 01:18 PM Thread Starter
docs
See attached
post #6 of 10 (permalink) Old 10-16-2018, 05:53 PM
Date registered: May 2010
Vehicle: 2016 GLE400, 2017 CLS550
"I read in a few places that if you touch the + and - main battery leads together after disconnecting the battery will force some kind of reset. ERRRRR I think I will pass on that one".
Touching (for as long as several seconds) the positive and negative cable ends together is simply a way to may sure that all capacitors in the electrical system are bled out. It gives you a more positive reset or reboot. Clearly the batteries are disconnected when performing a "hard reboot".
My first guess is there was a "spike" in the electrical system which probably blew a fuse somewhere. Worth checking all the fuses before testing all the bus networks
SRQAMG is offline
post #7 of 10 (permalink) Old 10-27-2018, 04:48 PM Thread Starter
Thanks
You are correct about the voltage spike. It caused a CAN bus B (Interior) to turn itself off.
Both an Autel DS808 and knockoff Xentry system (version 07/2018) listed the fault as stored and not current. Both tools would say they cleared the 2 codes in the Central Gateway, but they ALWAYS came back and clearing never made a difference.
The ultimate resolution for this was to spend fifty bucks for an Xentry online access key. I was then able to download and install an update for the Central Gateway, that finally cleared CAN bus codes out for good. Made no difference in restoring window/mirror control or trunk release.
Left front DCU had an available update, installing that got me drivers window, trunk release, and mirror control back. I had to flash the SCN coding for the other 3 DCU's to get window control back. After all of that the car is back to normal.
post #8 of 10 (permalink) Old 10-28-2018, 05:27 PM
Thumbs up
Good Job!
It's getting harder to change a battery these days.
We haven't encountered this particular scenario, but the odds of something going sideways during a battery change certainly increases with vehicle complexity.
At least there wasn't a hardware failure. If you want to see what the Munich crowd is dealing with, Google "Footwell Module.
SRQAMG is offline
post #9 of 10 (permalink) Old 10-29-2018, 05:56 PM Thread Starter
Thanks, hopefully info on this debacle will solve someone else's problem.
I think its TOTAL BS that charging/changing a battery according to MFG procedures causes these type of issues. It shouldn't require a dealership level diagnostic system to change a battery. I was under the impression that said procedures exist to prevent issues like this. The best or nothing, sigh
post #10 of 10 (permalink) Old 10-29-2018, 07:34 PM
[QUOTE=theonlykid1;17593257]Thanks, hopefully info on this debacle will solve someone else's problem.
Hopefully this will not become necessary at every battery change. But thanks to you, a lot of time will be saved knowing what to do and how to do it if needed.
SRQAMG is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C218 CLS-Class
