Sudden power loss - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-20-2019, 08:45 PM Thread Starter
Vegasbenztech777's Avatar
Date registered: Oct 2006
Vehicle: 2007 CL550
Quoted: 8 Post(s)
Sudden power loss
I have an 07 CL 550 and at times there is a sudden power loss that occurs. Usually midway through the warm up stage. You dont feel anything that would indicate something has happened but you hit the gas and there simply isnt any power. I shift to neutral and back to drive and power returns. I have DAS and there are no tranny codes or engine codes so this one is elusive. I did the trans adaptations and my shift quality is better but the issue is still there. Im thinking trans control module (conductor plate) may be going bad but I would be seeing some codes. I also thought maybe there is something going on in the ABS/ESP but also no codes. Its made my car a danger to drive as you need to count on there being full power when getting on the road with heavy traffic coming at you. Any ideas?
Vegasbenztech777 is offline
post #2 of 3 (permalink) Old 05-21-2019, 08:18 PM Thread Starter
Vehicle: 2007 CL550
Quoted: 8 Post(s)
Well I see no ideas but after thinking about the issue, I think it is most likely the TPS / Gas pedal. Tonight I cleaned the connector with some contact spray and I see improvement so I ordered a gas pedal on ebay. I will keep this posted for those few who care to know what fixed it in the end.
post #3 of 3 (permalink) Old 05-22-2019, 12:08 PM
Date registered: Aug 2017
Vehicle: 1990 300
I was thinking the same
LTpro is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C216 CL-Class
sudden loss of power, bad idle not drive-able poptopclk W220 S-Class 23 05-01-2019 01:42 AM
420SEL sudden loss of power - need help diagnosing bsconz W126 S,SE,SEC,SEL,SD,SDL Class 22 02-12-2015 06:22 AM
Sudden extreme power loss jaymos R/C107 SL/SLC Class 22 09-20-2014 06:52 PM
SL65 power loss after coil pack replacement - any advice? tranqfx R230 SL-Class 3 12-05-2012 07:15 PM
2000 Sprinter sudden power loss hakh W901-906 Sprinter 17 09-22-2010 03:49 AM
