Possible Serious ECU issue, how to replace? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-14-2019, 11:21 AM Thread Starter
Date registered: Mar 2014
Vehicle: 2002 CL500 W215
Hey All, so I've got an issue where my car will start up fine when cold, but once it's been driven for a few minutes and warmed up, it won't start up again until *something* cools back down. I had the local Mercedes dealership take a look at it and the tech said with 80% certainty that the ECU had gone bad and was causing this issue. He noted there is a LI (service bulletin) that addresses this issue L(54.21-P-052569. He noted that upon attempting to start the car again the fuel pressure was very low (around .5BAR, should be about 3.6BAR). Apparently this can be caused by something heating up in the ECU and then essentially not sending the correct signal to the fuel pump until the unit has cooled down. So my question is assuming he is correct and the ECU needs to be replaced, what are my options? I'd prefer to find a used one maybe from a vehicle being parted out. Does anyone know the process of having one programmed? My car is a CL550 but I'm assuming one from an S550 or W221 would work. Any help on this?
Blk02CL500 is offline
post #2 of 3 (permalink) Old 03-14-2019, 03:41 PM
rudeney's Avatar
Date registered: Dec 2004
Quoted: 1601 Post(s)
A more common problem is the crankshaft position sensor. It's located on the bell housing, behind the right-bank cam. Next time this happens, pour cold water on it to see if it helps. Note that without a signal from the CPS, the ECU will shut off the fuel pump as a safety feature.
- RODNEY
My Stable:
rudeney is online now
post #3 of 3 (permalink) Old 03-14-2019, 05:03 PM Thread Starter
Thank you for the tip. I may just replace the crankshaft sensor first since it is so much easier and less expensive.
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C216 CL-Class
Ignition Issue Spurs GM to Replace Keys AutoGuide.com AutoGuide.Com News 0 12-08-2014 04:10 PM
Another a/c might issue be serious this time :( baydoti C208/A208 CLK-Class 6 01-17-2012 12:43 PM
03 S430: How to replace spark plugs, air filter, fuel filter and a sunroof issue. laxexquis W220 S-Class 13 05-29-2010 01:46 PM
SERVICE MANUAL & INDEX 420 SE W126 S,SE,SEC,SEL,SD,SDL Class 3 08-29-2008 12:40 AM
Engine harness, throtlle body, injection ECU issue! josh190e W124 E,CE,D,TD Class 1 08-28-2008 01:26 PM
