New proud owner of a CL600 - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 10-13-2018, 01:36 AM Thread Starter
Ruindr's Avatar
Date registered: Mar 2015
Vehicle: 2007 CL600, 2003 SL55AMG, 1987 560SEL ECE, 1985 280SL
Quoted: 409 Post(s)
Cool New proud owner of a CL600
Greeting,
I am an active BW member in the roaster department, having owned several R107, R129 and R230 over the last few years. It was now time to "step up" into the major league of V12 cars
Attached a couple of pictures. 2007 model with 50K miles, well optioned. It really is the most luxurious car I've ever driven.
This forum seems a bit slow, but maybe people hang out in the w221 group instead? I'm a DIY guy and have Star diagnostics. It will be fun to work on this car!
ID:	2459231   Click image for larger version
ID:	2459233   Click image for larger version
ID:	2459235   Click image for larger version
wcbaird and jlexvold like this.
Stay flexible - keep smiling
Ruindr is offline
post #2 of 9 (permalink) Old 10-16-2018, 07:29 PM
jirutenberg's Avatar
Date registered: Nov 2002
Vehicle: 2015 S550 Edition 1 2014 CL600 Designo 2014 CLS550 Designo
Quoted: 2 Post(s)
Congrats to you. I find that people aren't usually happy for others acquisitions. Enjoy, I hope you have many years of trouble free driving. This is my 2014 CL600 a 1 of 1 of 55 built from 11-14.
wcbaird, ch.1953 and Ruindr like this.
jirutenberg is offline
post #3 of 9 (permalink) Old 12-03-2018, 05:13 PM
Date registered: Dec 2017
Vehicle: 2001 210.082 +494, 2008 221.176 +494
Quoted: 9 Post(s)
Originally Posted by Ruindr View Post
Greeting,
Hope you enjoy the car! They are pretty reliable overall, but make sure you take care of the ABC systems with proper flushing and maintenance. If something goes wrong with it and you have green hydraulic fluid all over you, you may retract your statement about it being "fun to work on this car!" LOL! But other maintenance items are not bad - the 24 plugs, the coil packs if you are unfortunate enough to have to change one/both, and I hope you are not as they are not inexpensive. Get your Telematics upgraded! I can see from the photos that it has not been done - and this only affects 2007 US and very early production 2008 models. It will give you additional useful Navi functionality and a new Video menu for DVD Video playback, and some stability improvements.
TiffanyTwisted is offline
post #4 of 9 (permalink) Old 12-03-2018, 11:55 PM Thread Starter
Ruindr's Avatar
Quoted: 409 Post(s)
@TiffanyTwisted - thank you for your comments!
I also have a SL55AMG with ABC so I'm well aware of this suspension. It's awesome when it works, but of course can be expensive to repair. This CL600 has a new pump and recent flush so it's at least a good base line.
Regarding upgrading Telematics - is this a dealer only job or do you know of alternatives? I have SDS myself, but I would assume an upgrade needs an online connection to dealer network?
Thanks.
Ruindr is offline
post #5 of 9 (permalink) Old 12-04-2018, 11:36 AM
Quoted: 9 Post(s)
Thanks.
Officially, it requires "Online Programming" and an SCN account. Technically, it does not.
It is carried out by inserting a CD (yes, CD, but many times incorrectly referred to as a DVD) into the COMAND. The official instruction say to eject all media from the COMAND and insert it into slot 1 (many insert it into slot 6 mistakenly and it still works - in reality, it probably doesn't matter) and COMAND will display Unknown Audio/Video Format on the display. Then you will go into Control Units -> Information and Communication -> Audio, Video, Navigation and Telematics, and select COMAND. Locate Control Unit Adaptations and select Control Module Programming. It will inform you to insert the Telematics disc in the COMAND and proceed, and you will be presented with a Xentry login box to log into Daimler. If you do not have these credentials, and your version of DAS is old enough and still has the option to do Offline coding, it will search for your VIN in the FDOK and if located it should proceed with the upgrade. I honestly cannot recall a vehicle having the information that DAS is looking for in the FDOK, so it does not proceed.
Of course, if your are technical, there are ways around it if your Xentry/DAS version is beyond the cutoff date of Offline programming. The newer versions *can* be technically modified to restore this feature, and you would need to place the file it is looking for in a certain location in the DAS folder structure as well as provide a DVD of the SDFlash Data in your optical drive (or alternatively, mount an SDFlash ISO in a virtual CD-ROM application). DAS will then instruct the COMAND to carry out the update, and this takes around 50 minutes. Keeping in mind that the W221/C216 has a high power draw with the ignition on/engine off, you will need to connect a very strong battery charger to the vehicle while it is being carried out, or simply go for a nice drive . It is fully unattended, and the update performs updates on all devices on the MOST ring, including the OASIS chipset on in the COMAND, the VCS (Voice Control System), SDARS (SiriusXM receiver), Sound/AGW module, Tele-Aid, DVD-Changer, etc. It is not complete until all modules are updated. It can mistakenly inform you that the update is complete after updating one module and request you eject the CD. DO NOT DO THIS - it will automatically proceed to the next module. If the CD is ejected automatically, it will pull it back in. It will be apparent when it has completed as it will return to the tuner and flashing activity will stop. It reboots several times during the process so do not be alarmed.
It is worth noting that modifying DAS is in violation of the EULA that you agree to when installing the software.
post #6 of 9 (permalink) Old 12-04-2018, 12:00 PM
jlexvold's Avatar
Date registered: Jun 2018
Vehicle: 2008 E350 4Matic Sport
Quoted: 13 Post(s)
Greeting,
Handsome model right there... Congrats!
Ruindr likes this.
jlexvold is offline
post #7 of 9 (permalink) Old 12-05-2018, 12:36 AM Thread Starter
Ruindr's Avatar
Quoted: 409 Post(s)
Thank you both for your comments!
@TiffanyTwisted - would you also happen to know where I can obtain a telematics upgrade cd? I have googled but to no avail yet. I only end up with NAV update DVD's...
Ruindr is offline
post #8 of 9 (permalink) Old 12-23-2018, 02:39 PM
Date registered: Sep 2003
Vehicle: 2016 E400 coupe, 2018 GLE350, 2007 CL600, 2019 C43 coupe
Quoted: 6 Post(s)
Congrats! I bought my '07 back in February with 63K miles. I have complete documentation of work performed, too.
That said, I installed new tires and had the suspension alignment for good measure. No problems whatsoever and she is put away for the Winter. I polished it before storage.
ID:	2475164   Click image for larger version
ID:	2475166   Click image for larger version
wcbaird is offline
post #9 of 9 (permalink) Old Today, 07:17 PM
ch.1953's Avatar
Date registered: Jul 2009
Vehicle: M120, M119, W126*2 + Silver Avantgarde wagon
Quoted: 223 Post(s)
Great looking car! - just superb.
Certainly not asking you to, but if later on you ever want to sell it, please do let me know...
Wonderful colour...
I hope you are enjoying her.
Leave people better than you found them...
ch.1953 is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C216 CL-Class
