Transmission Leak - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 06-20-2019, 04:30 PM Thread Starter
Date registered: Oct 2013
Vehicle: 2000 CLK430
Transmission Leak
Hello
I had a power steering hose blow and while the car was raised noticed the rear half of the transmission pan showed signs of a leak. This along with very minor and infrequent lag or kick from the transmission seems to confirm a leak.
I am not the original owner and see that the transmission fluid was changed 12/2014 by the dealer, and the car was serviced by amco 10/2015, 8/2016, 6/2017, 6/2018.
I called amco to see if they changed the tranny fluid and pan gasket bc if they did it should not be leaking -- maybe its under warranty but they need the plate number or prior owners name. Putting that aside,
I see this model requires a pump and does not have a fill tube. Is that correct. Is this a DIY repair
Also, I notice the front strut/shock absorber/suspension boots are cracked. Can those be replaced wo replacing the entire assembly.
Thanks
whjresq is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C215 CL-Class
