2001 W215 valve gasket cover - additional cover - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 04-27-2019, 07:04 AM Thread Starter
Date registered: Apr 2019
Question 2001 W215 valve gasket cover - additional cover
Hello everyone!
I'm the owner of w215 2001 CL-500, in which I have to change the gaskets in valve cover. Although, I suspect, that it's mandatory to change also the gasket under the cover, which I am not familiar with. It's marked in the picture below.
Can someone give me the OEM number for this particular gasket? I'd be really thankful.
Best regards,
Jacek
Jacbin94 is offline
post #2 of 5 (permalink) Old 04-27-2019, 04:56 PM
rudeney's Avatar
Date registered: Dec 2004
Quoted: 1718 Post(s)
There is no pre-made gasket for those breather covers. They are sealed with high-temp black RTV. There is an official MBZ part number for their RTV, but any will do. You might even want to use a quick-setting type so that you don't have to let it cure overnight.
- RODNEY
My Stable:
rudeney is offline
post #3 of 5 (permalink) Old 04-28-2019, 12:46 AM Thread Starter
Does the RTV rule match for the second cover from the driver side?
Jacbin94 is offline
post #4 of 5 (permalink) Old 04-28-2019, 08:13 AM
Black Swan's Avatar
Date registered: Sep 2015
Vehicle: 2010 E3504matic , 1998 E320
Quoted: 15 Post(s)
Yes both sides use RTV for the breather covers. You should also check the hose attached to those covers. Several suppliers sell kits that contain preformed replacement hoses and they're fairly inexpensive. FCP Euro should have the kit and have lifetime replacement on all parts.
rudeney and Jacbin94 like this.
Black Swan is offline
post #5 of 5 (permalink) Old 04-30-2019, 11:51 AM Thread Starter
Thank you very much! I'll definitely follow these advices!
Jacbin94 is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C215 CL-Class
::ECS Tuning:: Valve Cover Gasket Kit For Your W215 CL500 (2000-2006) ECSTuning C215 CL-Class 0 01-05-2015 10:30 AM
::ECS Tuning:: Valve Cover Gasket Kit For Your CL-Class ECSTuning C215 CL-Class 0 06-06-2014 10:06 AM
::ECS Tuning:: Valve Cover Gasket Kit For You SLK55 AMG ECSTuning R171 SLK-Class 0 06-05-2014 01:30 PM
::ECS Tuning:: Valve Cover Gasket Kit For Your CLK-Class ECSTuning C208/A208 CLK-Class 0 06-03-2014 08:34 AM
