Cl55 AMG Boot Lid Problem - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 04-02-2019, 07:26 AM Thread Starter
Date registered: Nov 2018
Vehicle: 03 CL55K AMG
hi i have a 2002 CL55K AMG with power boot lid.
in the last few weeks i noticed the electric motor was struggling to get the boot to rise more than 1cm but didn't think anything of it as it has always been temperamental.
I had just been letting it come up 1cm and then pushing the button with my hand to gently help it to get about 20% of the way and it goes up by itself.
However a few days ago when i tried to close the boot (never had any problems before) there was a noticeable clank noise (like metal on metal) and it got stuck about 15% away from being closed. it seems the lid actually closes at the rear first and then the part near the window seems to suck in and thats where it was stuck, i couldn't push it or anything, it just froze.
It automatically went back up and the motor seemed to be working fine, but when it was coming down, it got to around the same place (15% away from being completely closed), again clank noise and it stopped and back up again automatically.
i had to do this around 10-15 times before it eventually closed (but still with a small clank) so there is definitely something going wrong.
Has anyone experienced this? On visual inspection of the moving parts, all seems fine. Hinges/bolts etc look exactly the same either side, no visible play. This problem is happening on the same side as the electric motor (O/S i think).
I have a feeling it may be the gas struts at fault here but having difficulty identifying the problem and don't unnecessarily want to start taking things apart!!
I will try and post a picture of it when i get a chance, however i don't want to open and close it too many times as it may jam completely and not close at all!
amishb1 is offline
post #2 of 3 (permalink) Old 04-03-2019, 06:47 PM
GreenZZZ's Avatar
Date registered: Feb 2011
Vehicle: 2002 E320 SE, 2006 CL55 AMG
Quoted: 9 Post(s)
Its a hydraulic pump. I had my pump rebuilt. I think it was the same outfit that rebuilds the shocks for ABC suspensions. I've had to rebuild my trunk four times; 1) pump, 2) trunk pneumatic lock, 3) valet lock, 4) trunk seal. I don't even have 90k miles on my car.
GreenZZZ is offline
post #3 of 3 (permalink) Old 04-05-2019, 05:50 AM Thread Starter
thanks for this, it appears (after an hour stripping down the trunk) on the C215 CL55 the pump is actually located below the battery, or thats my assumption in any case as you can see the pneumatic pipes going below the battery, i will get to that later!
also, i have figured out the problem, it was the gas strut which was malfunctioning.
Unfortunately as it malfunctioned quite badly and i kept trying to close it, the little ball on the hinge where the gas strut sits is also bent which means a new hinge and strut! have attached a photo
thanks for your advice in any case, it has prompted me to check the pump and fluid inside.
amishb1 is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C215 CL-Class
Fan keeps running bossjj98 W163 M-Class 311 08-14-2014 05:42 PM
2012 ML63 Official Release and Video everythingmercedes W166 M-Class / GLE-Class 14 02-03-2012 10:46 AM
Sultan of Brunei's MBenz SL's [VIN] collection _S3C_ R129 SL-Class 27 01-04-2011 08:57 AM
2001 c180 boot lid problem rash_k W203 C-Class 0 06-09-2008 11:29 AM
Picture of the new S65! WOW WOW WOW!!!! Norb W221 S-Class 39 02-04-2006 11:00 AM
