CL55 Battery Tender - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 03-26-2019, 10:10 AM Thread Starter
joeythelyon's Avatar
Date registered: Mar 2019
Vehicle: 2006 CL55 AMG
Quoted: 2 Post(s)
CL55 Battery Tender
Hi everyone,
My 2006 CL55's battery died while I was away, and all power is lost in the car. This is what I've tried so far:
-I thought I could hook up my Battery Tender to my battery, so I unlocked the trunk using the key, but was not able to open it up all the way because of the hydraulic trunk opener struts.
-I pried open the carpet beneath the passenger side footwell and removed that foam thing and the metal foot plate and was able to access a variety of wires. Does anyone know if I can attach my battery tender to any of these connections so that I can get power back to my car? I don't have a jump starter or anything like that, only a battery tender.
I'm a long-time lurker on this forum, but this is my first time posting. I hope I'm not posting in the wrong section.
joeythelyon is offline
post #2 of 7 (permalink) Old 03-26-2019, 10:58 AM Thread Starter
Quoted: 2 Post(s)
Sorry, I didn't really ask for anything in my original quote. Does anyone know how I can maybe charge my battery so I can start the car? I would really appreciate it.
post #3 of 7 (permalink) Old 03-27-2019, 05:23 AM
renault12ts's Avatar
Date registered: Feb 2009
Vehicle: 2005 W215 CL500
Quoted: 214 Post(s)
Red is the positive...and any metal part of the body is the earth.
renault12ts is offline
post #4 of 7 (permalink) Old 04-01-2019, 06:12 PM
mohbaki's Avatar
Date registered: Feb 2008
Vehicle: 1990 W126 560 SEC White n Blue leather
Quoted: 16 Post(s)
Try to open the trunk with the metal part of your key FOB the old fashioned way.
Sent from my SM-G960F using Tapatalk
mohbaki is offline
post #5 of 7 (permalink) Old 04-04-2019, 03:11 AM
Quoted: 214 Post(s)
He did...and it opened...partly.
post #6 of 7 (permalink) Old 04-22-2019, 01:24 PM Thread Starter
Quoted: 2 Post(s)
It’s resolved now: I connected a lithium jump starter to the aforementioned leads, which allowed current through the car’s circuits. I then was able to open my trunk using the automatic lifts, then I replaced the battery with an made-in-Germany AGM from Walmart.
From what I know about battery tenders, they require a certain resistance across its leads to charge a battery. AGM batteries have very low resistance, so my battery tender may have “seen” it as a short circuit.
By the way, I did not try to force the trunk open, even though the latch opened and allowed the trunk to open maybe an inch and a half. Who knows what might have been damaged from that.
Thanks everyone for your help.
post #7 of 7 (permalink) Old 04-22-2019, 02:57 PM Thread Starter
Quoted: 2 Post(s)
The weird part here is that the area under the passenger footwell has two (2) red leads. I would connect to the battery directly if I could, but the battery is in the trunk with these cars, and I could not access it because of the hydraulic lift. I used the thicker red connection in the picture. That one connects straight to the battery.
Also, there are few grounds in the footwell area, since my car’s metal components there are mostly painted. I was able to use a stray bolt in there as a lead, and it was small and hard to attach to.
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C215 CL-Class
300D not charging watt.jeff W123 E,CE,D,CD,TD,TE Class 1 08-11-2015 06:12 PM
Battery Woes... cooljjay W123 E,CE,D,CD,TD,TE Class 2 04-20-2015 01:49 PM
battery question...... 1992300SL R129 SL-Class 7 10-14-2010 02:14 PM
Car battery opinions.... swoosh7777 W211 E-Class 44 01-21-2009 08:28 PM
Starting problems Ericeclass W210 E-Class 38 05-23-2008 07:47 AM
