Passenger door Lock - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 10-06-2011, 05:05 AM Thread Starter
JohnBosmans's Avatar
Date registered: May 2011
Vehicle: 2004 CL500
Passenger door Lock
maybe you guys can help me here. When I lock the car with the key fob or on the interior dash the PASSENGER door lock knob does not go down.
Same happens when the Auto Lock function kicks in at 15mph....the Drivers door knob goes down....but the PASSENGER knob stays up.
Any ideas??
JohnBosmans is offline
post #2 of 6 (permalink) Old 02-15-2017, 07:29 AM
renault12ts's Avatar
Date registered: Feb 2009
Vehicle: 2005 W215 CL500
Quoted: 214 Post(s)
Bumping this old one...I have the same.
renault12ts is offline
post #3 of 6 (permalink) Old 02-15-2017, 07:43 AM
pinkster's Avatar
Date registered: Jul 2013
Vehicle: 2002 S430
Quoted: 384 Post(s)
You have a leak in the system. The door locks work on air check the W220 Encyclopedia for this problem and how to fix it.
renault12ts likes this.
pinkster is offline
post #4 of 6 (permalink) Old 02-27-2017, 03:33 AM
Quoted: 214 Post(s)
It's working again..I had the battery disconnected for 24 hours for something else and when reconnected the lock is working!
post #5 of 6 (permalink) Old 02-27-2017, 06:44 AM
pinkster's Avatar
Vehicle: 2002 S430
Quoted: 384 Post(s)
When it stops working again, check the above link and fix the leak. No need to keep resetting it after you fix it.
pinkster is offline
post #6 of 6 (permalink) Old 07-11-2019, 11:48 PM
gnyteowl1's Avatar
Date registered: Nov 2011
I have same problem, passenger door lock won't go up or down unless I do it from inside.
gnyteowl1 is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C215 CL-Class
Passenger door lock beezybad W140 S-Class 4 03-16-2014 07:19 PM
Passenger door lock Mb9999 C209/A209 CLK-Class 3 05-27-2010 12:44 PM
Passenger door lock. mdrummond W123 E,CE,D,CD,TD,TE Class 3 06-22-2009 11:44 AM
passenger door lock DUVAL320 W163 M-Class 2 07-16-2008 06:18 AM
Door Lock not working on rear passenger door brian/ont W163 M-Class 2 07-25-2003 07:57 PM
