2005 CLK500 Rear Light Problems - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 07-26-2019, 03:43 PM Thread Starter
Date registered: Jul 2019
Vehicle: 2005 CLK500
Quoted: 2 Post(s)
Question 2005 CLK500 Rear Light Problems
Hey guys, I just picked up a CLK500 , and noticed the rear lights don't come on when I turn on the headlights. The brake lights, turn signals, and reverse lights all work in the rear though. I checked the bulbs on both sides, and they still look good. Checked all the fuses, and they look good still. Is there a relay for them somewhere? What else could it be? I ordered the manual for the car since it was missing when I bought it, but hasn't got here yet. Thank you for any help!
Fueler is offline
post #2 of 12 (permalink) Old 07-26-2019, 08:03 PM
rudeney's Avatar
Date registered: Dec 2004
Quoted: 1717 Post(s)
The exterior lighting is all controlled electronically by the SAMs (signal acquisition modules). If the rear tail lights don't work properly, you should be getting error messages (generated by the rear SAM, displayed on the instrument cluster MFD). If this doesn't happen, i'd suspect a defective rear SAM.
- RODNEY
My Stable:
rudeney is online now
post #3 of 12 (permalink) Old 07-26-2019, 11:13 PM Thread Starter
Quoted: 2 Post(s)
It said 3rd brake light out, but all of the brake lights are fine.
Fueler is offline
post #4 of 12 (permalink) Old 07-28-2019, 03:13 AM Thread Starter
Quoted: 2 Post(s)
So should I grab another rear SAM then? I was reading it would need to be programmed. Is that something you can do from the car, or will I need to haul it to the dealer for that?
Fueler is offline
post #5 of 12 (permalink) Old 07-28-2019, 06:37 PM
rudeney's Avatar
That 3rd brake light error is common. The LED strip can get small breaks in it internal wiring and although the lights work, you still get a fault.
If you get a SAM from a car exactly like yours (same morel, year and options) then it will need no programming.
- RODNEY
My Stable:
post #6 of 12 (permalink) Old 08-07-2019, 03:53 PM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 603 Post(s)
Where does it say that?
OP stated the 'rear lights', which we can assume to mean both left and right taillamps. If there is no +12 vdc at the sockets, the problem is probably the rear SAM, as rudeney has advised.
keyhole is offline
post #7 of 12 (permalink) Old 08-07-2019, 06:26 PM
rudeney's Avatar
Keyhole - he is the OP. It sounds like there are two problems. One is that the rear park lights do not come on with the headlights, but with no errors,. Then, there is a "3rd Brake Light" error. The lack of park lights (and without an error message) sounds like a SAM problem. The 3rd brake light error could be related, or it could just be a bad LED light bar.
- RODNEY
My Stable:
post #8 of 12 (permalink) Old 08-08-2019, 01:57 AM
keyhole's Avatar
Quoted: 603 Post(s)
So he is! I didn't notice that. I wish newbie posters gave us All the facts at the beginning....
keyhole is offline
post #9 of 12 (permalink) Old 08-08-2019, 02:32 AM
Benzyle's Avatar
Date registered: Nov 2013
Vehicle: MY05 CLK55 AMG , MY05 CLK320,Former,C180 Kompressor,Jensen Healey,Ford Capri V6,Alfa GTV.
Quoted: 306 Post(s)
If you want your third brake light to last a long time ,,,
Don't slam the trunk / boot lid.
Benzyle is offline
post #10 of 12 (permalink) Old 08-08-2019, 07:13 PM
rudeney's Avatar
Yeah, it seems to be more fragile than one would expect. On mine, I never slammed the lid but it still started giving me errors. I took it out and disassembled it expected to find some bad LEDs or broken wiring, but I found nothing visually wrong. I put it all back together, using clear silicone sealant to reattach the plastic lens. I tightened the bracket just enough to hold it in place, and all was good.
- RODNEY
My Stable:
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C209/A209 CLK-Class
