Hydraulic SCREW does not move or turn at all (Trying to manually open soft top) - Mercedes-Benz Forum
post #1 of 18 (permalink) Old 07-02-2019, 12:56 PM Thread Starter
michobebe's Avatar
Date registered: Jan 2011
Vehicle: S500v 4Matic 2003 - S600 V12 1998 (Sold) - E320 4Matic 1999 - E430 4matic 2001 - CLK320 conv 2004
Quoted: 9 Post(s)
Safety Lock SCREW on hydraulic reservoir is stuck (Trying to manually open soft top)
Hi guys, in my '04 CLK320 conv. I accidentally broke a limit switch, closed the roof on it, now stuck.
Now I'm trying to Manually open the soft top, I don't have the additional locking mechanism, only the screw (cf. Owner's manual P. 356). So I only need to turn the screw counterclockwise . Problem is this thing just WON'T move at all, I mean like even with excessive force that hurts my hands/fingers. Could such a screw be seized or is there another reason? Am I putting it at the right place?
Here are pictures of what I'M trying to turn. Ps I'm using a 5mm Allen (6mm doesn't fit ) (the factory one is no where to be found in the cars documentation case).
Name:	2019-07-02 15.55.12.jpg
ID:	2525082   Click image for larger version
Name:	2019-07-02 15.55.19.jpg
I daily drive the Best Thing Mercedes-Benz made at its Best Era:
The W140 S600 V12
What a pleasure!
michobebe is offline
post #2 of 18 (permalink) Old 07-05-2019, 08:31 PM
rudeney's Avatar
Date registered: Dec 2004
Quoted: 1695 Post(s)
No, that's the wrong one. It's the one on the left, directly under the hose clamp screw.
- RODNEY
My Stable:
rudeney is online now
post #3 of 18 (permalink) Old 07-06-2019, 12:28 AM
Benzyle's Avatar
Date registered: Nov 2013
Vehicle: MY05 CLK55 AMG , MY05 CLK320,Former,C180 Kompressor,Jensen Healey,Ford Capri V6,Alfa GTV.
Quoted: 299 Post(s)
A photo I have seen shows one which protrudes from the block...where Rodney said ..
could your one be missing ?
Benzyle is offline
post #4 of 18 (permalink) Old 07-06-2019, 12:46 AM Thread Starter
michobebe's Avatar
Quoted: 9 Post(s)
Thank you both! That's what I was afraid to hear... I think something is missing or broken in mine. Here are 2 pictures to illustrate.
what do you think ?
could it be moved manually with pliers, or maybe do something with that little pin/tiny hex? (the one over that left hole if you look closely)
Name:	2019-07-06 03.43.35.jpg
ID:	2525910   Click image for larger version
Name:	2019-07-06 03.43.41.jpg
The W140 S600 V12
What a pleasure!
post #5 of 18 (permalink) Old 07-06-2019, 02:12 AM
Benzyle's Avatar
Quoted: 299 Post(s)
Looks to me that your screw is missing ,,,the pin would enable the screw to press on the circular shape in the middle,,,
maybe you can exert a force onto that somehow ???
No guarantees that would work ,,but who knows ?
PS , Have a search below for the screw ,it might be there somewhere.
Benzyle is offline
post #6 of 18 (permalink) Old 07-06-2019, 06:54 AM
rudeney's Avatar
+1 on what Benzyle said. Unfortunately, that screw is not listed as a separate part, so if it is missing, you'd have to find a replacement on the secondary marker.
- RODNEY
My Stable:
post #7 of 18 (permalink) Old 07-06-2019, 07:11 PM Thread Starter
michobebe's Avatar
Quoted: 9 Post(s)
Oh Lord! Ok so if the main goal is to turn the round thing deep inside I could use different methodes to maybe for example scorch and make an indentation in the shape of a flat screwdriver in order to use one and turn the round thing inside.
What do you think of that idea? Because sourcing a complete reservoir only.for that screw would be a huge deal.
Does the little pin have any fonctionnal role ?
Thank you very much guys
The W140 S600 V12
What a pleasure!
post #8 of 18 (permalink) Old 07-06-2019, 09:19 PM
Benzyle's Avatar
Quoted: 299 Post(s)
No ,,,you misunderstand ..
The little pin just provides a stop for the screw to push against when rotated.
Have you searched for the screw in the areas below the unit ? A previous owner must have turned it too much ,,unscrewing it all the way out ,,maybe they dropped it and it is still down there somewhere.
Or maybe you don't need to do anything ,,if the screw had to be unscrewed ,counterclockwise , then because it is missing ,it is like that has already been done....If you had the screw it should only be turned anti clockwise one turn.
I now think that you don't need the screw to be able to manually open and close your roof ,,,you need two people ,follow the instructions in the manual. Be careful.
Perhaps you can now move the roof manually ? Have you tried ?
Benzyle is offline
post #9 of 18 (permalink) Old 07-06-2019, 09:52 PM Thread Starter
michobebe's Avatar
Quoted: 9 Post(s)
Ok my bad for misunderstanding. Yes I get it. Yeh I'll be looking for the screw early in the morning.
Actually I tried lifting the roof with a very strong friend of mine and we failed. I don't have the factory ropes so I made some of my own, then placed it behind the hinge, in front of the safety lock, closed the trunk and tried to lift, with no success.
The W140 S600 V12
What a pleasure!
post #10 of 18 (permalink) Old 07-06-2019, 10:51 PM
Benzyle's Avatar
Quoted: 299 Post(s)
Sorry to hear that ...I am not sure what else to suggest ,,
I'm afraid that even if you find the screw it will not solve your problem...
Benzyle is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C209/A209 CLK-Class
