lubricating cabrio top - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 06-17-2019, 09:54 AM Thread Starter
Date registered: May 2019
Vehicle: 2004 clk55 convertible
Quoted: 5 Post(s)
Hello,
From a previous thread I found some bits of dry brittle rubber washer pieces in the trunk after lowering/raising the top.
I'm going to guess I may some problems down the road. The car spent most of its life in texas, so heat was a factor.
I see 2 large hinges (black) when the trunk lid is open, should these be lubed? I also treated as much of the rubber trim/seals as
I can see and easily get to. I'm curious if there are other hinges/roof mechanicals to check and lube or other maintenance?
I'm a big fan of wurth products and have some rubber treatment/preservative as well as the hhs-k lubricant. I also have the
fluid film spray lube. I've also been quite interested in some of the superlube products with moly. I just want to reach out as
I'm fearful of overspray or lubrication product I use getting on the fabric top.
Happy motoring.
dgdrx is offline
post #2 of 7 (permalink) Old 06-17-2019, 05:44 PM
2000 C280 Sport's Avatar
Date registered: May 2008
Vehicle: Whatever car has the gas in it
Quoted: 74 Post(s)
This is very important to keep the rattles away and also for the life of the rubber to lubricate the seals. MB sells a special lubrication and if you apply it to the rubber the soft top becomes silent of noise. Same goes for the coupe as well with the windows. A very little goes a long ways and it has never let me down. I am still very surprised how little noise is inside the cabin of these cars. I would also lubricate the moving parts as well as it cannot hurt it. Just make sure not to use too much. On the soft top I use neverwet by rustnolium.
2017 Dodge Caravan (10K) NY
2015 GLK350 4Matic (22k) NY
2015 Mercedes ML350 4Matic (29K) NY (Wife's daily driver)
2012 Mercedes E350 4Matic Sport (48K) NY
2009 Mercedes CLK350 Coupe Designo (36k) NY
2006 Mercedes CL600 (49K) NY
2005 Mercedes CLK55 AMG Coupe (37K) FL
2004 Mercedes CLK320 Cabriolet (Facelifted 05-09 Interior). (53K) FL
1999 Ferrari F355 6 Speed (19K) FL
2000 C280 Sport is offline
post #3 of 7 (permalink) Old 06-17-2019, 08:52 PM
rudeney's Avatar
Date registered: Dec 2004
Quoted: 1695 Post(s)
Here's the WIS doc for soft top seal lubrication. The part number for MBZ's excellent lube is included. yes, a tiny vial costs ~$50, but it's worth it and it will last a "lifetime".
rcunningham321 likes this.
- RODNEY
My Stable:
rudeney is offline
post #4 of 7 (permalink) Old 06-18-2019, 04:16 AM Thread Starter
Quoted: 5 Post(s)
Sorry, but I don't see a link.
dgdrx is offline
post #5 of 7 (permalink) Old 06-18-2019, 06:06 AM
Date registered: Feb 2018
Vehicle: Triple black 2005 CLK500 Cabriolet
Quoted: 12 Post(s)
Each year I use Gummi Pflege on all the rubber seals I can reach on the cabrio - doors, windows, roof seams etc.
I also lube all the hinges I can reach - doors, roof etc - plan old white lithium grease in my case. A spray.
mcgsxr is offline
post #6 of 7 (permalink) Old 06-18-2019, 08:01 PM
rudeney's Avatar
Oops! Let me try that again:
http://benzbits.com/w209/soft_top/Lubrication.pdf
- RODNEY
My Stable:
rudeney is offline
post #7 of 7 (permalink) Old 06-30-2019, 07:26 AM
miko1aj's Avatar
Date registered: Sep 2012
Vehicle: '79 450SL, '04 CLK200 convertible; former A124, W210, A209.
Quoted: 107 Post(s)
+1 to everything my predecessors mentioned, plus when you open the trunk there are two hinges covered with black plastic cubes - you can easily remove them and grease the hidden hinges.
Regarding seals I use electric silicone grease, it's waterproof and long lasting.
miko1aj is online now
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C209/A209 CLK-Class
