Grill emblem and console screen compatibility '09 clk350 cabriolet - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-16-2019, 09:46 AM Thread Starter
Date registered: Jun 2019
First time buying a Benz and it feels like switching from Android to iPhone so forgive me for my naivete in advance.
My questions:
1. I would like to install an led front grill emblem but those which I can find for '09 era cars only state compatibility with c-class. Does this include my clk 350?
2. I would also like to upgrade the radio console display to touch screen. Is this possible for the '09 clk350 model I own?
Again, all apologies if these questions are stupid but any help is welcome. Thanks in advance!
Mickeydunham is offline
post #2 of 3 (permalink) Old 06-16-2019, 04:30 PM
gorj's Avatar
Date registered: Aug 2017
Vehicle: 2006 CLK 350 Convertible
Quoted: 105 Post(s)
Your CLK is not a C class. But if the diameter of the emblem is 6 5/8" then it might work. I have seen some of those advertised, but they did not look to have the quality of the MB star. Why not just add LED's to your existing star? As far as the radio goes, there are several units in the market place that work. Do a search on this forum and you will find several references. I have a JVC in mine and it works very well - even uses the MB steering wheel controls.
gorj is offline
post #3 of 3 (permalink) Old 06-16-2019, 06:40 PM
rudeney's Avatar
Date registered: Dec 2004
Quoted: 1694 Post(s)
Welcome to the forum! Please take a moment to visit the User Control Panel and update your profile to include your car model and year, and your location (at least country). This information will then appear below your name and avatar on the left side panel next to each post you make. This will greatly help others to give you better information. If you are using the mobile version of the site, you will need to switch to the "full" version to get to the User Control Panel.
You can put any double-DIN radio in your car. One option is to use an interface module to translate analog output to the MOST digital fiber signal the Harmon-Kardon amp needs. Another is to run new analog speaker wiring to the trunk and tie into the speaker wiring harness there, abandoning the HK amp.
- RODNEY
My Stable:
rudeney is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C209/A209 CLK-Class
