clk55 valeo radiator? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 06-05-2019, 03:01 PM Thread Starter
Date registered: May 2019
Vehicle: 2004 clk55 convertible
Quoted: 5 Post(s)
04 clk55 11/03 build date. I've seen anything after 09/03 is absolutely safe? I will have to confirm if I can find any markings on my radiator.
I've had the car 3 weeks (only on the road for 80 miles) mostly laid up from breather leak then gasket leak a week later. I recall reading a
post stating the clk55 transmission should be really smooth, I wouldn't agree based on my limited experiences. I've noticed some downshifts
when "coasting" downhill and it's a little noisy with whirling ? type "gear shifting" sounds on downshifts. The transmission was serviced
just before I purchased, I would hope I would have been FYI'd if something was discovered.
dgdrx is offline
post #2 of 4 (permalink) Old 06-05-2019, 03:32 PM
Supporting Vendor
AutohausAZ's Avatar
Date registered: Dec 2004
Vehicle: Too Many to List
Quoted: 31 Post(s)
You can check your chassis number against these applications: https://www.autohausaz.com/catalog/c...tor?s=d&page=1
Visit the AutohausAZ Vendor Section for special pricing for Benzworld members:
AutohausAZ is offline
post #3 of 4 (permalink) Old 06-05-2019, 06:42 PM
rudeney's Avatar
Quoted: 1691 Post(s)
It's fairly easy to tell based on the style of crimps use to connect the metal radiator to the plastic tanks.
This is the Valeo:
This is the Behr:
- RODNEY
My Stable:
rudeney is offline
post #4 of 4 (permalink) Old 06-06-2019, 12:30 AM
Benzyle's Avatar
Date registered: Nov 2013
Vehicle: MY05 CLK55 AMG , MY05 CLK320,Former,C180 Kompressor,Jensen Healey,Ford Capri V6,Alfa GTV.
Quoted: 297 Post(s)
dgdrx,,,
Even if you have a Valeo,, with a build date of 11/03 it should be fine.
Re The transmission ,, you could try resetting the adaptive shifts,,,
Also , sometimes services have not been done as claimed ...what exactly was done ?,,,,get a correct trans 722.6 dipstick and check the fluid level and quality,
If in doubt , drain the fluid , replace the filter and gasket and the electrical connector bushing...
It is a fun DIY. project.
When I got my CLK55 it would do some harsh downshifts at low speed ,,,after doing all the above,,,it is now quite smooth.
Benzyle is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C209/A209 CLK-Class
