Spark plugs - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 06-03-2019, 01:19 PM Thread Starter
laksa's Avatar
Date registered: Aug 2006
Vehicle: 2004 CLK 320 Elegance Cabriolet
Quoted: 21 Post(s)
Spark plugs
I was told my clk needs new spark plugs. Got the distinct feeling it’s going to be an expensive exercise. Why is this such an expensive exercise? Is it the cost of the plugs, intensive labour or both?
"When your temper rises, lower your fists- when your fist rise, lower your temper."
Chojun Miyagi
Founder of Goju Ryu Karate
laksa is offline
post #2 of 5 (permalink) Old 06-03-2019, 02:18 PM
chewtoy's Avatar
Date registered: May 2014
Vehicle: 2007 C230
Quoted: 82 Post(s)
Should not be an expensive service unless the plugs strip out the threads in their bores or some such. All are easily accessible without any bizarre contortions.
chewtoy is offline
post #3 of 5 (permalink) Old 06-03-2019, 03:33 PM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 600 Post(s)
How many miles on the clock? You might find this 4 y/o post on the same topic interesting.....
https://www.benzworld.org/forums/c20...ug-change.html
keyhole is offline
post #4 of 5 (permalink) Old 06-03-2019, 03:39 PM
gorj's Avatar
Date registered: Aug 2017
Vehicle: 2006 CLK 350 Convertible
Quoted: 103 Post(s)
It is not complicated. If you are handy you could do it yourself with just a few tools. You can see how it is done on You Tube. Just take your time. If do it yourself, after you gotten access to the plugs blow out the area around the plugs to prevent dirt from getting into the plug hole when removed.
gorj is offline
post #5 of 5 (permalink) Old 06-04-2019, 02:08 AM
Benzyle's Avatar
Date registered: Nov 2013
Vehicle: MY05 CLK55 AMG , MY05 CLK320,Former,C180 Kompressor,Jensen Healey,Ford Capri V6,Alfa GTV.
Quoted: 297 Post(s)
It is more costly than some cars because you need 12 spark plugs ,,usually NGK Laser Platinum,,,and it does take some time and skill to do the job,,,more so than on a Toyota.
Cheapest way for us in Australia is to buy spark plugs from the UK via ebay.,,,around $12 each vs $18 or more from local suppliers.
Benzyle is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C209/A209 CLK-Class
