clk55 fuel line disconnect - Page 3 - Mercedes-Benz Forum
post #21 of 26 (permalink) Old 06-03-2019, 03:15 PM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 600 Post(s)
Originally Posted by Benzyle View Post
Thanks for the chart ,,,my car is a W209 with engine 113.988,,,,does the chart still apply ?
Any idea what the difference is between 987 and 988 ?
I will guess that the chart is OK for both 987 & 988, but I cannot find what the the precise difference is. According to my WIS,
113.987 is used on 209.376, CLK55AMG coupe. 209.436, CLK55AMG cabriolet.
113.988 is used on 203.076, C55AMG coupe. 203.276. C55AMG cabriolet.
plus 209.376, CLK55AMG coupe. 209.436, CLK55AMG cabriolet.
Benzyle likes this.
keyhole is online now
post #22 of 26 (permalink) Old 06-03-2019, 03:54 PM
Benzyle's Avatar
Date registered: Nov 2013
Vehicle: MY05 CLK55 AMG , MY05 CLK320,Former,C180 Kompressor,Jensen Healey,Ford Capri V6,Alfa GTV.
Quoted: 297 Post(s)
Thanks , mine is a 209.376,,, I just wondered why the wis chart split them between 203 and 209,,,I doubt that there is any difference.
Benzyle is offline
post #23 of 26 (permalink) Old 06-03-2019, 03:57 PM
Benzyle's Avatar
Quoted: 297 Post(s)
Originally Posted by dgdrx View Post
Just took a little ride and so far no leak, but we need to drive more. I did notice a slightly rougher "stumbling" idle, very subtle. I did disconnect the battery and
replaced a few breather hoses as well as clean the MAF sensor. I have read about a throttle "position/switch or the sort" reset sometimes required?
Any ideas/suggestions or do I just need to drive for a bit and let the "computers" reset/figure it out?
If the rough idle persists then double check all your hose connections and make sure you have the air box correctly seated down on the intake.
Benzyle is offline
post #24 of 26 (permalink) Old 06-06-2019, 12:31 AM
Benzyle's Avatar
Quoted: 297 Post(s)
dgdrx ,,,
How is your gasket leak repair ? Any update ?
Benzyle is offline
post #25 of 26 (permalink) Old 06-06-2019, 06:24 PM Thread Starter
Date registered: May 2019
Vehicle: 2004 clk55 convertible
Quoted: 5 Post(s)
Thanks much for reaching out. I've only had opportunity to put 20 miles after the fix but so far so good.
dgdrx is offline
post #26 of 26 (permalink) Old 06-07-2019, 08:39 PM
Benzyle's Avatar
Quoted: 297 Post(s)
Good to know it worked ok ...
Benzyle is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C209/A209 CLK-Class
