09 w/M272 motor oil weight? - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 05-21-2019, 06:21 PM Thread Starter
chewtoy's Avatar
Date registered: May 2014
Vehicle: 2007 C230
Quoted: 82 Post(s)
Question 09 w/M272 motor oil weight?
Hi,
No owners manual, so want to double check. I recall that my old C230 took 5w40 synthetic oil, and it had the same motor.
Is this the correct weight for the 09 M272 motor as well?
Also, if someone can direct me to an online owners manual, pdf or other format, I'd be grateful. Official MBZ only goes back to 2012.
Thanks!
chewtoy is offline
post #2 of 11 (permalink) Old 05-21-2019, 08:06 PM
rudeney's Avatar
Date registered: Dec 2004
Quoted: 1665 Post(s)
You just want ot use an oil from this chart:
https://bevo.mercedes-benz.com/bevolisten/229.5_en.html
Since you are in a fairly mild climate that doesn't get very cold, you can use a 5w40. You may find the Mobil 1 0w40 more easily, though. As for the owner's manual, MBUSA claims they have it online, but it's not there. I have a few in my repertoire:
http://benzbits.com/w209/2009_clk350...0_clk63amg.pdf
chewtoy likes this.
- RODNEY
My Stable:
rudeney is offline
post #3 of 11 (permalink) Old 05-21-2019, 09:04 PM Thread Starter
chewtoy's Avatar
Vehicle: 2007 C230
Quoted: 82 Post(s)
Red face
Thanks! And THANK YOU for the pdf!
Amazon has lubri-moly on sale for less than Mobil 1: https://www.amazon.com/Pack-Liqui-Pr.../dp/B00IHI7JYW
chewtoy is offline
post #4 of 11 (permalink) Old 05-22-2019, 07:24 AM
gorj's Avatar
Date registered: Aug 2017
Vehicle: 2006 CLK 350 Convertible
Quoted: 100 Post(s)
Personally, I think Mobile One is over rated. This is the same thing:
https://www.amazon.com/Castrol-03084...s%2C228&sr=8-4
chewtoy likes this.
gorj is offline
post #5 of 11 (permalink) Old 05-22-2019, 09:00 AM Thread Starter
chewtoy's Avatar
Vehicle: 2007 C230
Quoted: 82 Post(s)
I run castrol in my other cars. It's become a good oil. And that price is right!
chewtoy is offline
post #6 of 11 (permalink) Old 05-22-2019, 10:55 AM
rudeney's Avatar
The only reason I use Mobil 1 0w40 is because it's readily available and not too expensive. My local Walmart carries it in 5 quart jugs for about $27 each. Last time I was in there, they only had one jug, so I found the Castrol Edge 0W-40 A3/B4 and used it. I think it was pretty much the same price, or maybe $1-$2 less.
chewtoy likes this.
- RODNEY
My Stable:
rudeney is offline
post #7 of 11 (permalink) Old 05-22-2019, 11:07 AM
260e crusier's Avatar
Date registered: Nov 2010
Vehicle: 1999 E320, 2005 C230K SS, 2010 Accord LX w Eibach & Koni FSD's
Quoted: 486 Post(s)
Mobil 1 0w40 is currently at Walmart for $22.88 (5qt jug). If they don't have it in stock, order online and pickup later.
260e crusier is offline
post #8 of 11 (permalink) Old 05-22-2019, 12:19 PM
gorj's Avatar
Quoted: 100 Post(s)
I live in a rural area and I have been purchasing my synthetic oil at a farm supply store that sell a brand called Rural King from Mid States Distributing. It has an API rating of SN and meets or surpasses the ILSAC G5 - same as Mobile One. Every so often they have it on sale for $2.50 a quart. A Real bargain. Use it in my tractors and my cars.
gorj is offline
post #9 of 11 (permalink) Old 05-22-2019, 05:13 PM
rudeney's Avatar
If it does not meet the MB 229.5 spec, then you should not use it for the extended (10K+ mile) change interval. You should change at no more than 7K mile intervals.
chewtoy likes this.
- RODNEY
My Stable:
rudeney is offline
post #10 of 11 (permalink) Old 05-22-2019, 05:38 PM
gorj's Avatar
Quoted: 100 Post(s)
Since I only put about 5 to 7 k a year on the car, I change it once a year no matter what! And rarely is it driven at more than 70 MPH.
gorj is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C209/A209 CLK-Class
