Cruise control issue - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 05-19-2019, 02:52 PM Thread Starter
Date registered: Apr 2019
Vehicle: W209 CLK 320 2003
I have some problems with my cruise control, I get cruise control on screen when I pull the lever down, but immediately when I release lever it disappears from screen and cruise control wont engage. If I pull lever top nothing happens, I've try spray some electric spray into the base of cruise control lever but with no difference.
Picture is when I hold the lever down, as mention before it does not engage cruise control. I have no warnings lights on, Ive checked fuses but everything seems to work, also my break lights is working, whats next thing to do?
Zipfer is offline
post #2 of 13 (permalink) Old 05-19-2019, 07:27 PM
rudeney's Avatar
Date registered: Dec 2004
Quoted: 1662 Post(s)
It does seem like a bad lever. Do you get any different messages when you pull or push the lever?
- RODNEY
My Stable:
rudeney is offline
post #3 of 13 (permalink) Old 05-20-2019, 11:12 AM Thread Starter
Nothing happen beside that cruise control text comes up when I pull and hold lever down. Up nothing happen, torwards me nothing happen and so on. I can also activate limit speed if I push lever in and hold it down.
Zipfer is offline
post #4 of 13 (permalink) Old 05-20-2019, 07:37 PM
rudeney's Avatar
There may be some differences in model years, but I think if the cruise control has not been set since the engine was started, and you pull the lever for resume, you should get a blinking "---mph" message. If not, then I'd guess it's the switch itself that is bad.
- RODNEY
My Stable:
rudeney is offline
post #5 of 13 (permalink) Old 05-21-2019, 09:18 AM Thread Starter
I’ve ordered a new stalk I will report back when I have changed it.
Zipfer is offline
post #6 of 13 (permalink) Old 05-24-2019, 12:24 PM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 597 Post(s)
You do realize that the Cruise Control needs the wheels to be matched in diameter to compare the wheel speeds, so do check for equal tire wear and matching sizes. Of course the front and rear tire widths are different - but that does not affect the diameter. Also the RPM sensors could give trouble.
I am not sure if any of those issues will prevent you setting the CC active...
keyhole is online now
post #7 of 13 (permalink) Old 05-26-2019, 12:54 AM Thread Starter
Yes I've read about that tire size can affect cruise control engage in some speed range, but in my case cruise control wont engage at all, and all my tires does have correct size. I have no warning lights on my dashboard I guess an faulty RPM sensor would throw one of those?
Zipfer is offline
post #8 of 13 (permalink) Old 05-26-2019, 03:01 AM
Date registered: Dec 2016
Vehicle: 2009 CLK 350
Quoted: 15 Post(s)
I haven't checked for the W209, but most cars with cruise control have a switch that's engaged by the brake pedal as soon as you touch it. If this switch has failed the cruise control will not engage. Contort yourself under the dash and check whether there's a switch visible.
Anker is offline
post #9 of 13 (permalink) Old 05-26-2019, 05:32 AM
rudeney's Avatar
There is no brake pedal switch on the W209. Also, if it were tire size related, you'd be getting ESP errors. Pulling the stalk toward you when cruise has not been set should result in a message on the MFD like "---mph". This is to let you know it has not been set to a speed, so it cannot resume. Since this does not happen, I suspect a bad stalk. The only caveat I'll offer to that theory is I am not sure if all model years (i.e. version of the instrument cluster) would display this message, and I am not sure if it is displayed in all countries.
- RODNEY
My Stable:
rudeney is offline
post #10 of 13 (permalink) Old 05-26-2019, 04:30 PM
Benzyle's Avatar
Date registered: Nov 2013
Vehicle: MY05 CLK55 AMG , MY05 CLK320,Former,C180 Kompressor,Jensen Healey,Ford Capri V6,Alfa GTV.
Quoted: 286 Post(s)
I don't know if this applies to your car ,,,
Check whether cruise control is selected,,,The LIM indicator lamp in the lever should not be lit.
If the lamp is lit ,press the lever toward the column ..to select cruise control.
If the LIM lamp is lit , then the Variable Speedtronic is selected and cruise control will not work.
keyhole likes this.
Benzyle is online now
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C209/A209 CLK-Class
cruise control issue - help! Vladdd C215 CL-Class 5 02-18-2018 03:56 AM
Mercedes Fault Codes... These Will Get You Out Of Trouble......one Day ! ;) Sarge786 V-Class 53 10-22-2017 01:19 PM
1998 E 320 cruise control and turn signal switch issue Nomad13 W210 E-Class 4 10-02-2016 09:41 AM
Bosch KE-Jetronic Overview isthisdave R/C107 SL/SLC Class 16 11-20-2012 03:33 PM
Useful links 4 new members - repost Bazzle R170 SLK-Class 79 02-06-2011 09:45 PM
