Convertible adjustment - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-14-2019, 09:14 AM Thread Starter
Date registered: Jul 2012
Vehicle: 2000 clk 430 convertible
Quoted: 12 Post(s)
07 Clk350 convertible.
Is there a way to adjust the convertible top, or at least make sure that itís sitting tight. (I keep searching the web and canít find anything for adjusting)
I notice a small gap in the rear under the glass. (Not to mention the rattling when going over bumps). When I open and close the top the gap is not there, but after some time I notice it.
BK627 is offline
post #2 of 3 (permalink) Old 05-14-2019, 08:36 PM
rudeney's Avatar
Date registered: Dec 2004
Quoted: 1694 Post(s)
There should be no gap there, but there is no adjustment. Maybe the bow is bent?
- RODNEY
My Stable:
rudeney is offline
post #3 of 3 (permalink) Old 06-17-2019, 10:18 AM Thread Starter
Quoted: 12 Post(s)
The bow definitely looks a little bent. Iím not sure if itís affecting anything (other then that small gap you see in the picture. Iím going to take a look again when I get a chance see if thereís anyway of straightening it out.
BK627 is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C209/A209 CLK-Class
K-Jetronic WITH Lambda Overview and Adjustment Myndex R/C107 SL/SLC Class 38 07-16-2019 01:43 PM
Convertible Top Rear Tension Cable Adjustment? jrthe1 R/C107 SL/SLC Class 17 07-08-2019 06:52 AM
Need a new EHA(Electro hydraulic actuator) Jevo2 W124 E,CE,D,TD Class 77 02-02-2017 11:26 AM
Advantages of a convertible crb49 R/C107 SL/SLC Class 5 06-17-2008 06:04 PM
