Fuel Door Latch - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 04-18-2019, 06:04 PM Thread Starter
gorj's Avatar
Date registered: Aug 2017
Vehicle: 2006 CLK 350 Convertible
Quoted: 100 Post(s)
Fuel Door Latch
I have often wondered why the fuel door latch only engages when the engine is started. It seems to me it would make more sense if the door were latched when the vehicle is parked and not running - to prevent theft of your fuel. All other vehicles I have owned that had a fuel door, latches had to be activated by a button or lever inside the vehicle before they would open. I do know that one should never open the fuel cap when the engine is running, but it would seem having a theft deterrent would trump that.Today, with idiots running around putting "stuff" in fuel tanks, there is even more of a reason to have a locking door! What were the German engineers thinking?
gorj is offline
post #2 of 11 (permalink) Old 04-18-2019, 11:15 PM
Benzyle's Avatar
Date registered: Nov 2013
Vehicle: MY05 CLK55 AMG , MY05 CLK320,Former,C180 Kompressor,Jensen Healey,Ford Capri V6,Alfa GTV.
Quoted: 287 Post(s)
Hi Gorj ,
I never knew it locked when the engine is running ,,,,you learn something every day,,,
If it locked when the car was parked (and not locked ) ,,how would you open it to re-fuel ?
When you lock the car ,,the fuel flap locks at the same time...giving you security.
Benzyle is offline
post #3 of 11 (permalink) Old 04-19-2019, 12:01 AM Thread Starter
gorj's Avatar
Quoted: 100 Post(s)
Originally Posted by Benzyle View Post
Hi Gorj ,
I did not know that. I have never tried to open the fuel door when the vehicle is locked. So the engineers are smart - the door is only open when the vehicle is unlocked and the ignition is off. That makes sense. A 2006 Mercedes has better technology than my wife's 2017 vehicle loaded with all the latest technology, yet you have to pull a lever to open the fuel door!! But I do like the adaptive cruise, the push button start, the navigation, and the lane departure warning in her car.
gorj is offline
post #4 of 11 (permalink) Old 04-19-2019, 12:49 PM
IWantedaJag's Avatar
Date registered: Jan 2014
Vehicle: 2008 AMG CLK63 Conv., 2012 R350 4-Matic, Wife's 2015 C300 sedan
Quoted: 2490 Post(s)
I've never tried opening it when driving either, although rightly or wrongly I long ago stopped switching the engine off when fuelling. I figure if modern tires conduct well enough to conduct lightning they conduct well enough to dissipate static (even if the engine wasn't running and they didn't it would spark on the pump nozzle and kaboom!) and engine heat is too far away to worry about.
"Semper In excretio, solum profundum variat" - unknown
They called me mad, and I called them mad, and damn them, they outvoted me" - Nathaniel Lee
IWantedaJag is online now
post #5 of 11 (permalink) Old 04-19-2019, 02:21 PM
rcunningham321's Avatar
Date registered: Jul 2017
Vehicle: 2005 CLK 320 black/black
I also like most of the modern touches, but I'm not yet ready for lane departure warning. I've had it on rental cars and it feels like someone else is also driving the car with me - no thanks.
I'll stick with basic 2005 CLK features. One thing that did surprise me on my car was the rain-sensing wiper system. Still don't see that on some more modern cars.
rcunningham321 is offline
post #6 of 11 (permalink) Old 04-20-2019, 06:23 AM Thread Starter
gorj's Avatar
Quoted: 100 Post(s)
Switching the ign off while refueling is no so much about causing a fire but it messes with the evap control system. I have even seen the check engine light come on after refueling with engine on.
gorj is offline
post #7 of 11 (permalink) Old 04-22-2019, 05:39 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 597 Post(s)
Over here in the UK, fuel filling stations often have a prominent sign instructing drivers to stop the engine while filling.
keyhole is offline
post #8 of 11 (permalink) Old 04-22-2019, 07:51 AM Thread Starter
gorj's Avatar
Quoted: 100 Post(s)
I remember seeing signs posted like that here in the US, but have not seen them recently. It has always just made sense to me to turn off the engine. But I live in "bubba" country in Arkansas where they do not do much that makes sense - like drive 4 wheel drive pickup trucks that are two foot off the ground!
gorj is offline
post #9 of 11 (permalink) Old 04-25-2019, 08:27 AM
keyhole's Avatar
Quoted: 597 Post(s)
I was surprised to read this recent statement, and I doubted that it was so. However, like others here I had never checked it (until today) and I can report that on my 2004 CLK the fuel flap does not lock immediately with the engine running. Maybe later models are different?
Of course, if the cluster is set to 'automatic locking', all the doors, the trunk lid and the fuel flap will all lock after the car reaches 9 mph.
Incidentally, in an emergency you can unlock the fuel flap manually by turning a release knob located behind the right side trim panel in the trunk. This is covered in the Operator's Manual.
Benzyle likes this.
keyhole is offline
post #10 of 11 (permalink) Old 04-27-2019, 04:53 PM
rudeney's Avatar
Date registered: Dec 2004
Quoted: 1662 Post(s)
The fuel door locks and unlocks with the other doors and trunk. If you are in the car with the engine running and the doors are locked, and you only open the driver's door, the other doors (and the fuel door) stay locked. However, if you shut the engine off and open the driver's door, then all doors (including the fuel filler).
- RODNEY
My Stable:
rudeney is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C209/A209 CLK-Class
Report: Fukushima, Japan Reactor Now In Meltdown After Explosion eurospec380se Off-Topic 669 06-26-2017 05:06 AM
W140 Fix it Yourself Articles Merc600sec W140 S-Class 265 11-04-2015 11:17 PM
Fuel System Service Procedure - Fuel Distro, Lines and Injectors BenzHacker R/C107 SL/SLC Class 10 03-29-2010 04:36 AM
Code Help! jporrata W202 C-Class 10 07-31-2009 08:02 PM
Fuel pressure regulator Vs accumulator NewMBie W126 S,SE,SEC,SEL,SD,SDL Class 2 03-22-2005 01:03 AM
