2007 CLK63 TPS location Error Code P2122 - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 04-03-2019, 12:49 PM Thread Starter
Date registered: Mar 2018
So I am getting P2122 error code stating the TPS circuit D has low voltage. I can't for the life of me pinpoint it exactly on the driver's side Anyone have any idea where it is? Should I remove the gas pedal and access it through there? Much appreciated!!
Skorp is offline
post #2 of 5 (permalink) Old 04-04-2019, 08:02 PM
rudeney's Avatar
Date registered: Dec 2004
Quoted: 1597 Post(s)
First of all, stop using a generic OBDII scanner and get a tool that can read native MBZ DTCs.
- RODNEY
My Stable:
rudeney is offline
post #3 of 5 (permalink) Old 04-05-2019, 07:46 PM Thread Starter
....I use a $400 interactive scan tool that has all vehicles from Porsche to Mercedes to Saab that does it all from reset oil light to calibrating cps sensor.
Anyone else can help me? This is 100% the problem as my car won't respond when I push the gas pedal taking 5 to 10 seconds to accelerate.
Skorp is offline
post #4 of 5 (permalink) Old 04-05-2019, 08:06 PM
rudeney's Avatar
i was not suggesting your tool was inferior or cheap, but it only reads generic OBDII codes from your car. Because it is required by the government, MBZ's systems are compatible with OBDII, but they have their own set of internal codes that are more descriptive and more specific to MBZ's electronics than what OBDII provides. MBZ's SDS (Star Diagnosis System) is their own tool that does this, and you can buy a Chinese "clone" for under $500 for a turnkey system. There are also some other 3rd party tools like the Autel M8022 Elite and two iCarsoft models (i980 and MBII) that will read MBZ's codes.
Without the MBZ-specific DTCs, you'll be swapping parts and hoping you eventually swap the right one.
- RODNEY
My Stable:
rudeney is offline
post #5 of 5 (permalink) Old 04-10-2019, 12:09 PM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 588 Post(s)
If you are referring to changing the 'accelerator pedal sensor' (B37) - following my WIS it doesn't look too difficult, but I have not done this myself.
File Type: pdf W209 r - i accelerator pedal sensor.pdf (504.3 KB, 3 views)
keyhole is online now
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C209/A209 CLK-Class
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
1999 S600 Vin markcedes W140 S-Class 152 01-26-2018 09:03 AM
TPS Location? Capt. E 430 W210 E-Class 20 12-17-2008 04:24 PM
New 2007 C230 Owner- Battery Location? azitpro General Mercedes-Benz 2 03-07-2008 03:43 AM
