CEL - Need to vent. - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 08-25-2017, 02:24 AM Thread Starter
Date registered: Nov 2007
Vehicle: 2004 CLK500
Quoted: 31 Post(s)
Question CEL - Need to vent.
I replaced the Crankshaft Position Senor on 2/3/2015 with a Lemforder due to P0335 and another recent one on 8/14/2017 with Lemforder due to P0335. The CEL lit up last night. I'm getting it scan later on today. If it does show up as P0335. Should I just replace it with a Bosch brand or is there something else I should look into? Maybe camshaft sensor's or flywheel?
amusa is offline
post #2 of 8 (permalink) Old 08-25-2017, 03:51 AM
Benzyle's Avatar
Date registered: Nov 2013
Vehicle: MY05 CLK55 AMG , MY05 CLK320,Former,C180 Kompressor,Jensen Healey,Ford Capri V6,Alfa GTV.
Quoted: 297 Post(s)
Bosch is generally the number one choice.
P0335 is Crank P S, I don't think camshaft sensor is the problem.
Did you do this? 'Start the engine and slowly bring the rpms up over a period of 2 minutes from idle to 2500 rpms,this allows the new cps to index itself to the ECU and really set it into sync with the flywheel indexers.Do it and the car will run better,don't do it and you may never know what you are missing'.
Is the car running ok?
Benzyle is online now
post #3 of 8 (permalink) Old 08-25-2017, 04:31 AM Thread Starter
Quoted: 31 Post(s)
I had my friend did the CPS for me since he own a Indy shop and reset the ECU/ECM the last time it was changed. The car drives fine with no issue. I drove it home last night and this morning to the office with the CEL light on. I know for a fact that I have (2) engine motor mounts shot. There on my to do list.
Should I go ahead and try to sync it anyway?
amusa is offline
post #4 of 8 (permalink) Old 08-25-2017, 05:14 AM
Benzyle's Avatar
Quoted: 297 Post(s)
You may as well,it's easy enough to do.
Then drive it for a week or so and see what happens.
Some people would say if the car is going well,then don't tamper with it....but that is up to you...if it keeps throwing a CEL probably worth trying to fix it.
post #5 of 8 (permalink) Old 08-25-2017, 11:13 AM Thread Starter
Quoted: 31 Post(s)
I'm heading to the shop in an hour. Can't hold the RPM here at work. I wait till I get to the shop and I'm already praying that I can make this 40 minutes of highway driving to the shop.
amusa is offline
post #6 of 8 (permalink) Old 08-28-2017, 03:00 AM Thread Starter
Quoted: 31 Post(s)
I had it scanned last Friday. The code was a P0456 EVAP System Small Leak. I checked the filler gas cap and I was able to tighten it with a 1/2" turn. I cleared the code for now.
amusa is offline
post #7 of 8 (permalink) Old 08-28-2017, 09:15 PM
rudeney's Avatar
Date registered: Dec 2004
Quoted: 1692 Post(s)
You may want to replace the gas cap gasket.
- RODNEY
My Stable:
rudeney is offline
post #8 of 8 (permalink) Old 09-11-2017, 07:06 AM Thread Starter
Quoted: 31 Post(s)
Thanks, The CEL never came back on after I tightening the filler cap and reset the light. I'm getting ready to replace all (3) mounts just need to order the rear should be able to get it the same day thru my friend supplier (World PAC). I'm waiting on the front to arrive that I bought last week. I'm going with Lemforder.
amusa is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C209/A209 CLK-Class
