Rear power window/motor DIY - Page 14 - Mercedes-Benz Forum
post #131 of 134 (permalink) Old 05-31-2019, 02:14 AM Thread Starter
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 600 Post(s)
Yes. You could just briefly touch the disconnected contacts (and reverse the polarity) to prove that the motor works in both directions. However, the motor rotation could be jammed by a broken lifting mechanism. There are no fuses here to protect the motor. The module looks after that situation when connected normally.
I would prefer to remove the motor completely and apply the 12v power at a work bench. No chance of further damage then, and it should rotate freely.
keyhole is online now
post #132 of 134 (permalink) Old 05-31-2019, 02:59 AM
Benzyle's Avatar
Date registered: Nov 2013
Vehicle: MY05 CLK55 AMG , MY05 CLK320,Former,C180 Kompressor,Jensen Healey,Ford Capri V6,Alfa GTV.
Quoted: 299 Post(s)
Thanks Keyhole ,,
The thing is ,,I have fitted new cables and main pulley and slide block,,,and so the thing I want to test is the mechanism,,to make sure it moves the way it should. I can't put it in the car ,,because I already fitted another unit from a wrecker....
I am pretty sure that the motor will run ok .
Thanks again.
Benzyle is online now
post #133 of 134 (permalink) Old 06-02-2019, 02:29 PM
Date registered: Jun 2018
Vehicle: 2004 CLK320 Cabrio
Putting 12 volts to the black and green connectors allowed me to bench test the regulator prior to installation. The cables loosened up a bit and the trolley moved as it should in both directions. In the full "up" position, the bracket that holds the window won't clear the opening, so you have to install it in the "down" position, then raise it to line up access holes to easily install the glass...Steve
koolhandluke is offline
post #134 of 134 (permalink) Old 06-03-2019, 01:47 AM
Benzyle's Avatar
Quoted: 299 Post(s)
Yes,,,I did the same ,,,happy to report the trolley bracket moved nice and smoothly and to the end of travel in both directions,,,,so it seems that quite tight cables are just the way they are supposed to be..
Thanks again..
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C209/A209 CLK-Class
1993 Mercedes 190e rear passenger power window motor spree17 For Sale/Wanted/Trade/Giveaway 3 06-27-2010 03:11 PM
e320 rear window regulator / window motor failure 60bugeye General Mercedes-Benz 6 08-19-2007 05:59 PM
Rear power window motor problem dtabler W123 E,CE,D,CD,TD,TE Class 1 06-04-2007 11:58 AM
W126 rear door, rear window glass, window roof motor, door cards, rear plastic panels, ECU Peter Seow For Sale/Wanted/Trade/Giveaway 0 12-27-2005 07:07 AM
Change the Rear Right power window motor ViRuSeR_190E W201 190-Class 4 10-07-2005 07:50 PM
