Electric front seat headrest stuck up - Mercedes-Benz Forum
post #1 of 20 (permalink) Old 08-09-2010, 08:14 AM Thread Starter
Date registered: Dec 2006
Vehicle: 2002 CLK320 W209
My driver's seat headrest is in the fully up position, and not responding to the 'down' switch. Passenger side is all working fine. I've seen this general problem mentioned quite a few times on the forums, usually with slightly varying symptoms. These are mine:
- The rest retracts fully when I tip the seat forward, and extends fully when I tip it back again.
- When I press the up switch I can hear (a relay?) under the seat go click.....click..click. (I also hear this on the passenger side, when its fully extended).
- When I press the down switch I hear nothing. (The passenger side also makes no noise, pressing the down switch when it is fully *retracted*).
- Immediately after locking the seat back, while the rest is *still extending*, if I press the up switch then it stops part way. I can't make it stop by pressing the down switch, only the up. (Mind you, after doing this, *none* of the driver's seat switches work until I tip seat forward/back again, and let the rest extend fully!)
Before seeing all the similar posts I had been assuming it was a faulty switch, and that still does seem to best fit my symptoms. But I'm reluctant to chuck it at the dealer and perhaps end up paying for un-necessary parts.
Anyone got any ideas of other things to try...?
Thanks
colh is offline
post #2 of 20 (permalink) Old 08-09-2010, 10:18 AM
FLCLK320's Avatar
Date registered: Mar 2010
Vehicle: 2004 CLK 320
I have this same problem. When I bought the car it was at the right height so I never even thought of it.
Then my son found the console switch and moved his headrest up and down. He then did it on his side (the passenger side) with his switch and no problem. I then tried mine and no movement whatsoever. Again, it's not a major problem for me as it's set right for my head. But, I'd like it to work.
I'll be watching the thread for any ideas!
FLCLK320 is offline
post #3 of 20 (permalink) Old 08-09-2010, 12:28 PM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 600 Post(s)
I think that you are right in your assumption here.
The headrest is retracting when you fold the seat by an alternative mechanism (Hall effect sensor?) but that does prove that the motor & module is OK.
All that leaves is the up/down switch on the door & cabling. You have checked the underseat connectors, I'm sure.
keyhole is offline
post #4 of 20 (permalink) Old 02-15-2011, 12:55 AM
M-Rods's Avatar
Date registered: Oct 2009
Vehicle: 2004 CLK 500 Previously: 2001 CLK 430
I have the same issue, drivers headrest stuck in the top position, and the switch causes no response, underseat connectors? I'll have to look for those. Is there a manual way to get it down?
Oh you have a Mercedes....you think you're better than me? No, but I have a better car
M-Rods is offline
post #5 of 20 (permalink) Old 02-15-2011, 03:25 AM
560sec944's Avatar
Date registered: Jun 2010
Vehicle: 1999 SL500, 2004 CLK500, 2006 Cadillac SRX
Do a search on seat controller. My passenger seat headrest was fully extended with the seat tipped forward and was jammed against the windshield. The seat controller is easily accessable - under the seat with all motors plugging into it. Find the headrest motor plug, unplug it and put power to it to run it down. You'll probably should check the wire diagram.
Unlike any other.
560sec944 is offline
post #6 of 20 (permalink) Old 02-16-2011, 05:55 PM
fourml8r's Avatar
Vehicle: 2005 CLK55 AMG CABRIOLET
i had the same exact problem. headrest was fully extended and jammed against the windshield.
fourml8r is offline
post #7 of 20 (permalink) Old 02-17-2011, 07:39 AM
FLCLK320's Avatar
Where might I/we find the wiring diagram?
FLCLK320 is offline
post #8 of 20 (permalink) Old 02-17-2011, 12:59 PM
560sec944's Avatar
Good question - maybe Keyhole has it in pdf?
Unlike any other.
post #9 of 20 (permalink) Old 02-18-2011, 07:25 AM
keyhole's Avatar
Quoted: 600 Post(s)
Hi Guys - yes I have found the circuit details for ESA (electric seat adjustment). They are spread over 3 pages, with the legend.
I also have had my headrest stuck at the top once when the driver's seat was folded. I managed to force it back, but it was a scare! Since then - no problems.
While searching for this seat position control module (N32/1 and N32/2) circuit, I read something in the WIS about the 'block' feature (stopping the motors with memory) and the seat 'normalize' feature. This is news to me today. I have read nothing about normalizing the seats before.
As I understand it, to normalize the seat, you move it as far to the front as it will go, and hold the switch for 3 secs. Then move it back, and do the same. Whether you have to do that to every seat motor, I'm not sure
I'm going to dig into the WIS a bit further, to try to understand this feature, and will report anything I discover here.
keyhole is offline
post #10 of 20 (permalink) Old 04-09-2013, 06:07 PM
Date registered: Apr 2013
Headrests
Were any of you able to solve the headrest motor problem? My drivers side headrest is stuck up but when i fold the seat forward it drops. Any help is most appreciated!
roblazar is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C209/A209 CLK-Class
190E front electric seat removal (with no power) pascalgodin General Mercedes-Benz 4 09-28-2014 06:49 PM
Front seat stuck GHM W124 E,CE,D,TD Class 3 07-31-2007 08:17 PM
Front seat headrest rattles, can they be switched? E430_4Matic W210 E-Class 7 04-09-2007 02:58 AM
Front Seat Electric Connection Differences??? mcbear W126 S,SE,SEC,SEL,SD,SDL Class 2 11-12-2005 08:15 PM
Help! Front seat electric motor died... ccweems W163 M-Class 8 11-25-2002 10:57 AM
