2003 CLK-320 Convertible - Instrument Cluster Removal - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 05-18-2019, 09:09 PM Thread Starter
Date registered: Nov 2005
Vehicle: 1997 E-420, 2001 E-320, 2007 S-550, 2009 E-350
Quoted: 26 Post(s)
Send a message via Yahoo to hadam
Hi all, I have 2003 CLK-320 convertible. I need to remove the instrument cluster to fix the Pixel issue on it.
I have Mercedes removal tool that I use on my Mercedes 2001 W210 E-320 instrument cluster to remove it.
On CLK-320, I don't see any room to insert the tool into to pull the Instrument cluster out. Is there any trick or some special way to pull Instrument cluster out?
Please any help will be appreciated.
2001 MB E-430 Gone- Totaled
2009 MB E-350
2001 MB E-320
2003 MB CLK-320 Cabriolet
1997 MB E-420
2007 MB S-550
2011 MB G-550
hadam is offline
post #2 of 5 (permalink) Old 05-19-2019, 02:01 AM
Date registered: Oct 2013
Vehicle: 1997 C140 S500, 2003 CLK430 Cab, 2005 E320 4MATIC Wagon
Quoted: 16 Post(s)
burgca is offline
post #3 of 5 (permalink) Old 05-19-2019, 02:04 AM
Quoted: 16 Post(s)
burgca is offline
post #4 of 5 (permalink) Old 05-20-2019, 11:28 AM Thread Starter
Quoted: 26 Post(s)
burgca, thank you. I was able to remove the instrument cluster. I tried to put hard foam piece between the ribbon cable and the padding. It did not work, look like on W208, when pixel goes bad on ambient temperature, the connection of ribbon cable to board is quite far off and not touching.
Same method worked on W210 IC, but not on W208. I will look into other approaches or just send IC of W208 to professional services to fix it for $149.
2009 MB E-350
2001 MB E-320
1997 MB E-420
2007 MB S-550
2011 MB G-550
hadam is offline
post #5 of 5 (permalink) Old 05-20-2019, 11:29 AM Thread Starter
Quoted: 26 Post(s)
https://www.benzworld.org/forums/w21...01-w210-e.html
2009 MB E-350
2001 MB E-320
1997 MB E-420
2007 MB S-550
2011 MB G-550
hadam is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C208/A208 CLK-Class
W124 Online Manual Index for M103 cbc atl W124 E,CE,D,TD Class 31 01-12-2019 08:35 PM
Instrument Cluster - Removal MarJa W163 M-Class 36 12-30-2017 01:05 PM
FS: parting out several 98,99,00,01 ML's sc_mopar For Sale/Wanted/Trade/Giveaway 1 01-21-2016 01:06 AM
burlwood instrument cluster upgrade w140nz W140 S-Class 6 02-16-2015 07:54 AM
Instrument Cluster Removal Gone Wrong Friendly Ghost W140 S-Class 34 11-20-2010 02:29 PM
