Comand 2.0 w208 weird issue - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 04-02-2019, 03:41 AM Thread Starter
Date registered: Apr 2019
Quoted: 4 Post(s)
Question Comand 2.0 w208 weird issue
Hi there, first of all I'm new here and I would like to thanks in advance any help I could get from this forum.
Yesterday I was trying to check what hapen with the comand 2.0 of my second hand CLK w208, it had never worked.
When I was going to take it out... see what happened (video link) the unit works by pressing it by the sides!!!! and it goes black again when you releases it.
I don't have any idea what on earth is going on there.
Any help would be appreciate.
Many thanks
Antonio del Hoyo is offline
post #2 of 5 (permalink) Old 04-14-2019, 10:52 PM
CH4S Artist
Teutone's Avatar
Date registered: Sep 2004
Vehicle: 1985 500SEC, 1991 190E 2.6.
Quoted: 1700 Post(s)
Many thanks
Welcome to the forum.
Click 'Forums' on the top toolbar for the drop down menu, and scroll down to W208. Daimler Benz made different versions of same model cars for different parts of the world, so to get the correct information on an international forum like benzworld, location can be important.
Location can be added to your profile by clicking 'User CP.'
You can also search the W208 forum archive by using the google special search on top, the other search function can be quite cumbersome if you are new to it.
I copied your thread to W208.
Cheers
Antonio del Hoyo likes this.
Teutone is offline
post #3 of 5 (permalink) Old 04-15-2019, 11:27 AM Thread Starter
Quoted: 4 Post(s)
Many thanks Teutone!
post #4 of 5 (permalink) Old 04-15-2019, 01:49 PM
CH4S Artist
Teutone's Avatar
You are Welcome.
The forum has quite a few members from your Country, and fellow admin RedLiner lives way South of you
Teutone is offline
post #5 of 5 (permalink) Old 04-16-2019, 03:06 PM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 588 Post(s)
.......the unit works by pressing it by the sides!!!! and it goes black again when you releases it.
First, I have never examined my COMAND when removed from the car.
However, this must be an electrical issue,and is probably a dry-joint on a printed circuit board that is slightly flexed when the sides of the unit are pressed.
It could be a nightmare to locate such a fault, unless known working PCBs can be substituted in the unit. Once the faulty PCB is identified, an expert can usually find the bad soldered joint.
keyhole is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C208/A208 CLK-Class
Real Weird Electrical Issue Jeremy Clarkson W210 E-Class 0 02-01-2019 09:08 AM
1996 c220 Weird Transmission Issue Evan Caillouet W202 C-Class 1 07-09-2018 12:40 PM
Weird Sirius Radio Issue? azkeith W164 M-Class 1 03-08-2017 11:27 AM
2000 W208 CLK430 odd brake issue...or is it? ontheball247 C208/A208 CLK-Class 3 06-16-2012 05:23 AM
Weird electrical issue. Please help me out! dieselsmoke300d W123 E,CE,D,CD,TD,TE Class 4 03-23-2012 05:46 PM
