Convertible Top Replacement - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 10-19-2018, 04:45 PM Thread Starter
3dogsrock's Avatar
Date registered: Sep 2018
Vehicle: 2000 CLK 320 Convertible (Work In Progress)
Quoted: 4 Post(s)
Hello Everyone!
I have a 2000 CLK320 with a damaged soft top. I have found very good deals on new ones but cannot find a video on the correct replacement steps. I believe I know how but just wanted to check first.
If anyone can point me to a video with the complete installation process it would be much appreciated!
Thanks in advance.
3dogsrock is offline
post #2 of 7 (permalink) Old 10-20-2018, 04:11 PM
Date registered: Dec 2007
Vehicle: 2001 CLK320 Cabrio
Quoted: 31 Post(s)
This link has the MB WIS instructions and plenty of pictures.
https://mbworld.org/forums/clk-class...anvas-top.html
serndipity is offline
post #3 of 7 (permalink) Old 10-21-2018, 12:38 PM Thread Starter
3dogsrock's Avatar
Quoted: 4 Post(s)
Thanks again!!!!!
post #4 of 7 (permalink) Old 11-28-2018, 02:35 PM
Derekwh's Avatar
Date registered: Oct 2007
Vehicle: 2002 CLK55 AMG, 2014 GLK250
Quoted: 7 Post(s)
Originally Posted by 3dogsrock View Post
Thanks again!!!!!
Did you replace your top? How difficult was it?
Derekwh is offline
post #5 of 7 (permalink) Old 03-26-2019, 05:36 PM Thread Starter
3dogsrock's Avatar
Quoted: 4 Post(s)
I did not replace it. I removed all of the tape and used Convertible top cleaner/Black. That did an outstanding job on renewing the black, and removing the discoloration of the tape that the former owner used.
I did the following until I get a new top: After a total cleaning, I made sure that the rip was fully filled with waterproof material so it would look even with the rest of the top. And then I used Flex Seal black spray over 1 piece of black gorilla tape that covered the 20" rip. It actually looks pretty good! I will replace the top eventually, but I really want to get it painted first
Carl
post #6 of 7 (permalink) Old 03-27-2019, 05:30 PM
alpac's Avatar
Date registered: Aug 2013
Vehicle: 1992 500SL, 1999 CLK 320 conv, 2015 ML350, (2011 ML550 gone, C320 wagon gone, 2005 C240 gone)
Quoted: 89 Post(s)
.... And then I used Flex Seal black spray over 1 piece of black gorilla tape that covered the 20" rip. It actually looks pretty good! ...
Could you possibly show a pic of the result? My old SL's soft top could use some refreshing
alpac is offline
post #7 of 7 (permalink) Old 04-23-2019, 03:47 PM Thread Starter
3dogsrock's Avatar
Quoted: 4 Post(s)
Sorry it took so long to reply. I attached some photos of the repair. After using one strip of gorilla tape, then spraying with flex seal it is definitely livable to me! I also bought some convertible top cleaner and dye to blend it in.
ID:	2507082   Click image for larger version
ID:	2507084   Click image for larger version
ID:	2507086   Click image for larger version
ID:	2507088   Click image for larger version
ID:	2507092   Click image for larger version
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C208/A208 CLK-Class
