CLK... ABS/BAS/ASR Warning Light QUICK FIX HERE - Page 2 - Mercedes-Benz Forum
post #11 of 11 (permalink) Old 05-25-2019, 01:47 PM
260e crusier's Avatar
Date registered: Nov 2010
Vehicle: 1999 E320, 2003 E320 Wagon, 2005 C230K SS, 2010 Accord LX w Eibach & Koni FSD's
Quoted: 492 Post(s)
Originally Posted by 3dogsrock View Post
My ABS, ESP and BAS lights have been on since I purchased my CLK 320 Convertible A208 a year ago. I have tried everything mentioned in these forums. So, I purchased a Craftsman 1681 scan tool, it is the same as an Innova 5100. Both of these are compatible with my vehicle and should read the ABS codes. The scanner will read everything else on the vehicle, however, when I ask it to read ABS codes it tells me that I am not connected to the vehicle!. I am connected because I just ran a full diagnostic! Called support and they have no idea except to say that my vehicle is not communicating with the scanner when checking ABS. Any help in this issue would be appreciated.
ABS/ESP/BAS codes have to be scan thru the 38 pin port. You will need a compatible multiplex adapter. Cheap Ebay ones will not work.
Did you check your battery voltage? Resync steering angle sensor?
260e crusier is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C208/A208 CLK-Class
2005 c230 Alternator warning light and ESP warning light Oaklandish W203 C-Class 11 04-06-2013 09:57 AM
Flashing low fuel warning light and check engine light. BErbach W210 E-Class 9 11-14-2012 07:33 AM
Quick question about warning lights decampos R/C107 SL/SLC Class 21 09-01-2010 04:29 PM
Stop light and exterior light warning indicator tempoct R170 SLK-Class 8 06-16-2004 03:17 PM
Park Brake warning Light and Low fuel warning light Ameet Patel R170 SLK-Class 3 03-21-2001 03:28 PM
