Valvoline MaxLife ATF vs. MB ATF - Page 5 - Mercedes-Benz Forum
post #41 of 64 (permalink) Old 10-10-2012, 09:25 PM
Pancho's Avatar
Date registered: May 2004
Vehicle: 2000, 430CLK Cabriolet
Originally Posted by kaigen View Post
follow up
I changed the oil with Mobil ATF134 7 months ago. The car runs perfectly since then.
Good to hear it. I've heard of other folks using the Mobil product w/o a problem.
CLK430 Cabriolet, bought it new in year 2000, Chassis# W208, Trans#722.623, Engine #113.943
Pancho is offline
post #42 of 64 (permalink) Old 01-26-2016, 07:21 PM
Date registered: Jan 2016
Vehicle: CLK320 ML320 ....
Your assertion that Maxlife is made with conventional oil is wrong. Base oil does not mean that it is petroleum based.
SaabVolvoMBJoe is offline
post #43 of 64 (permalink) Old 03-16-2018, 06:59 AM
Date registered: Dec 2017
Vehicle: 2003 C240 87k // 2002 C240 77k Miles
Quoted: 22 Post(s)
So any updates from folks who used Valvoline MaxLife so far? That would be great to know.
Jay11 is offline
post #44 of 64 (permalink) Old 03-16-2018, 07:03 AM
Date registered: Feb 2012
Vehicle: C320 Wagon 2002
Quoted: 2 Post(s)
100000 miles / 5+ years with Shell ATF134. Works perfectly, zero issue.
Jay11 likes this.
kaigen is offline
post #45 of 64 (permalink) Old 03-16-2018, 04:29 PM
Pancho's Avatar
Roger that, Shell works. The $26/Qt MB branded stuff is for the uninformed. Been using Maxlife w/o a prob since forever. I think it's about $3 at Walmart. Works like a charm.
mrboca and Jay11 like this.
Pancho is offline
post #46 of 64 (permalink) Old 03-17-2018, 04:30 PM
Date registered: Jan 2018
Vehicle: 98 c280, 02 clk430
Quoted: 124 Post(s)
so, how effective is flushing through the lines at clearing the old fluid from the torque converter?
Das_ist_gut is offline
post #47 of 64 (permalink) Old 03-17-2018, 08:40 PM
Pancho's Avatar
Works very well for me. Flushed until it came out red. As I recall, took about 15 quarts (At $3/Qt. it's not a problem.). Check some of the postings, either here or MB-world. Several have posted info on it. I disconnected one of the cooler lines, and clamped a clear poly hose draining into a gallon jug marked a 1 Qt., and, with a friend at the wheel, and I under the car, pumped out a Qt. at a time, added a Qt. at a time, until it comes out red. That was about 50K+ miles ago. I bought my 430CLk Cabriolet new, and she still runs nicely and still looks classy. Now note, Maxlife is spec for the W208 trans (722623, 5 speed). I believe the W210 is different.
Pancho is offline
post #48 of 64 (permalink) Old 03-18-2018, 07:38 AM
Quoted: 22 Post(s)
I came across this method by AxelAddict, a well known Toyota guru. Granted subject car was a camry (3k oil changes) but you can appreciate the concept and see where this is going eventually...tranny drain & fill with every oil change, if you want to skip flushing. Guy asking had bought a 99 Camry and didn't have maintenance records/history.
Jay11 is offline
post #49 of 64 (permalink) Old 03-18-2018, 09:01 AM
Quoted: 124 Post(s)
well, I have 2 to do, the c280 needs it the most it is a high miler and is most likely in need of fluids, If I bought the german stuff I would exceed the purchase price of the car in one change.
I see there is a different shifter in the clk to the c I need to figure out if they upgraded the trans for the V8, can you search it from the VIN?
98 c280 sport with V6
02 clk 430 w amg package (pretty sure this is just plastic and tires)
Mark.
Is the dex/mercon fluid the stuff? there are about 5 kinds of max life on the castrol site.
post #50 of 64 (permalink) Old 03-18-2018, 09:24 AM
260e crusier's Avatar
Date registered: Nov 2010
Vehicle: 1999 E320, 2003 E320 Wagon, 2005 C230K SS, 2010 Accord LX w Eibach & Koni FSD's
Quoted: 489 Post(s)
I've been doing this on all of my cars. Might be an overkill, fluid comes out looking clean and red every time. Filter gets changed every fourth time (40K miles).
I use my Harbor Freight oil extractor (6+ gallon capacity) so it's a clean and easy job.
260e crusier is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C208/A208 CLK-Class
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
ATF Mobil 1 full synthetic vs MB ATF rudedude W163 M-Class 120 05-08-2017 04:39 PM
Royal Purple MAX-ATF Multi -Spec High Performance ATF clb0099 W163 M-Class 1 01-14-2008 09:19 AM
ATF Dipstick/ ATF Fluid Change and Electronic Transmission JNLeChevet W140 S-Class 1 03-02-2005 07:30 AM
ATF leak on 86 420SEL..and "STOP LEAK ATF" ? Help pls. AAA of NY W126 S,SE,SEC,SEL,SD,SDL Class 4 05-17-2004 09:10 AM
ATF leak on 86 420SEL..and "STOP LEAK ATF" ? Help pls. AAA of NY W126 S,SE,SEC,SEL,SD,SDL Class 3 05-14-2004 08:08 AM
