Driver seat not working right on E400 cab - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-03-2019, 03:20 AM Thread Starter
Date registered: May 2019
Trying to go back and forth using door controls the left side works OK but the right side goes a little bit then jams. Tried to find anything that was causing the jam but everything is packed under the seat. Not too confident on removing seat, looks like four bolts, and if I screw it up Iíll be in a world of hurt as I need car for work.
gerry863 is offline
post #2 of 3 (permalink) Old 05-03-2019, 08:53 AM
konigstiger's Avatar
Date registered: Jan 2007
Vehicle: '71 Pinto
Quoted: 366 Post(s)
Covered under warranty, out of warranty only choice is to remove seat to inspect most common problem motor shaft. Shaft cannot be purchased separately however, MB does offer a repair kit left 0009107802, right 0009107902.
konigstiger is offline
post #3 of 3 (permalink) Old 05-05-2019, 07:13 AM Thread Starter
IT looks like the DC motor is part of the kit. That kit costs around $500! My motor works but it just stops at one point in the worm gear and wont go much in either direction. It tries to and moves a little bit in each direction.
Possibly it has something caught in the worm gear and I'm not over confident I can remove seat, find problem and reattach seat. Given the Mercedes labor rates I'm damned if I do and damned if I dont
gerry863 is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C207/A207 E-Class Coupe & Cabriolet
2000 ML430 Driver Seat Stuck panfreak W163 M-Class 1 06-29-2015 07:26 AM
1988 560 sel Driver power seat and telescoping wheel not working brenman8 W126 S,SE,SEC,SEL,SD,SDL Class 4 03-02-2015 07:37 AM
driver seat removal without battery power Fuzzydog W124 E,CE,D,TD Class 2 10-26-2011 05:23 AM
Fixing stuck rear seat ML series atss2006 General Mercedes-Benz 0 10-11-2011 07:33 AM
Driver power seat is not Working luasilva W163 M-Class 2 08-29-2008 02:05 PM
