Replacing E350 Wood Trim - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 01-15-2016, 08:04 AM Thread Starter
Date registered: Jan 2016
How easy or difficult is it to replace the wood trim panels on the doors and above the glove compartment? Mine (E350 2010) have either warped or fell off.
Can these be purchased separately at a reasonable price? And from where? Should the replacement be done professionally or can this be done by an amateur? I confess that I actually broke one of them as I tried to peel it out
Look at the attached picture to figure out what I mean if it is not clear.
mmsdh is offline
post #2 of 4 (permalink) Old 01-18-2016, 01:20 PM
Date registered: Mar 2015
Vehicle: 2011 E350 Cabriolet
My 2011 E350A Cabriolet had the same problem on the drivers door----It was fixed under warrantee-------now the panel over the glove box is loose on one side---I am not sure if these are glued or snap in. Disapointed in Quality in this aspect of the car. Good luck---I look forward to responses on your post for reference.
Art Brzostowski is offline
post #3 of 4 (permalink) Old 07-30-2019, 05:58 PM
Date registered: Jul 2019
Vehicle: 2012 E350 Coupe
Same thing happened with mine.
Ms P is offline
post #4 of 4 (permalink) Old Today, 09:11 AM
konigstiger's Avatar
Date registered: Jan 2007
Vehicle: '71 Pinto
Quoted: 385 Post(s)
Attached replacement instructions. Need VIN to supply trim part #s.
konigstiger is offline
  Mercedes-Benz Forum > Mercedes-Benz Coupe/Convertible Forums > C207/A207 E-Class Coupe & Cabriolet
