R129 Audio Sound System Issues/Problems - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 07-31-2015, 08:40 AM Thread Starter
RobbieV845's Avatar
Date registered: Mar 2011
Vehicle: 1994 SL500 (wife's) I have too many cars to list.
Quoted: 8 Post(s)
Send a message via AIM to RobbieV845
Hey MBies,
I got the code from someone on here and the radio appears to be working it goes through the stations
and bands no sound comes out of the speakers.
I checked the rear Amplifier's 30 amp fuse on the sub and it was good. The car has two dash speakers,
four door speakers and two rear speakers and I don't get any sound from any of them.
Does anyone know of any other fuses that could have blown or effect the amp not not the radio?
And if the amp is bad, how do I know for sure without spending $100 on a used one.
Looking for helpppppppppppp.
Thanks in advance - Rob.
ID:	1553913   Click image for larger version
Robbie V
"Wife's - 1994 SL500 (R129.067)"
American Muscle Car Collector
(Buy - Sell 60' - 70's)
RobbieV845 is offline
post #2 of 5 (permalink) Old 07-31-2015, 10:24 AM
LWB250's Avatar
Date registered: Jan 2013
Vehicle: 65 220SEb, 97 SL500, 98 E320 Wagon, 2002 E320, former W108/W112/W114/W123/W124/W126/W140/W220
Quoted: 1027 Post(s)
I would start at the radio and see if there is any output.
If you have a Becker 1492 or 1692 you've got a Bose system. If that's the case, the radio outputs are high level, that is, they are powerful enough to drive a speaker, albeit a small one.
With that in mind you could just take a pair of headphones or some small speakers and with some jumpers to check the output at the radio. If you have output at the radio you can pretty much figure it's the amplifier.
You could also give Eddie or Tom at Becker Autosound a call and see if they can provide some high level troubleshooting.
I would guess it's the amp based on the fact that you have no sound at all.
Dan
LWB250 is offline
post #3 of 5 (permalink) Old 04-19-2019, 10:48 AM
Date registered: Aug 2010
Vehicle: 600SL 1994
Quoted: 2 Post(s)
did you ever figured out what was wrong? i have the same issue (plus antenna not rising)
grooviness is offline
post #4 of 5 (permalink) Old 04-19-2019, 05:48 PM Thread Starter
RobbieV845's Avatar
Quoted: 8 Post(s)
I sent both to a guy in Florida, Im sure a Googke searcher someone on here can direct you to who, he fixed the radio the amp was fine. Didnt charge for diagnosis
He also put a 3.5 mm Jack on it so I can hook my phone/mp3/iPod to it to call and/or play music through the speakers. I play Sirrius thru my phone. And as far as the antenna, its toast and needs replacing. Get an aftermarket one they'll last a few years.
Good Luck.
Robbie V
post #5 of 5 (permalink) Old 04-20-2019, 06:53 AM
Skylaw's Avatar
Date registered: Oct 2004
Vehicle: 2013 S550
Quoted: 437 Post(s)
A little casual looking at the first forum page here reveals a "sticky" in the blue backgrounded area at the top of the page, dealing with component-level repair of mercedes electronics. Check it out.
Warren
2013 S550
Formerly:
2010 S550
2005 S500 4-Matic
2000 S500
1978 450SL
Skylaw is offline
  Mercedes-Benz Forum > Mercedes-Benz Technical Forums > Audio & Telematics Forum
